Old 02-01-2005, 09:24 PM
bonehead bonehead is offline
Default LE 6.4 upgrade auth code? validate?
Hi - did a quick search on this - still lost.
i needed to restore a Ghost image of my C drive, realized it put me back to 6.1 (was at 6.4). Just re-DL'd the 6.4 upgrade and installed - d\go to launch it and it asks for Authorization code 'for upgrades, code is on iside cover of...' blah blah.
I've done this before but can't remember where i got this code from. It won't take my 6.1 code.
li'l help
thanks
tb
001 - PTLE 6.4
Dell P4 2.53Ghz 768mhz Ram
160gb 7200 internal audio
20gb system 60gb storage
Radeon 128mhz dual head video
Old 02-01-2005, 09:32 PM
SimpleNatureSpirit SimpleNatureSpirit is offline
Default Re: LE 6.4 upgrade auth code? validate?
6.1 uses the same code as 6.4. Obviously you found your code, but several systems were sent out with the wrong codes. They should be 3 sets of 8 letters/numbers. If ithat is what you found in your 'getting started' manual, then try the variations for i&1's, O/0, etc.
You won't find anyone here giving up codes but if you are registered, Digi CS will provide you a valid code. Just email them.
Share the gift gifted to you
Old 02-01-2005, 09:37 PM
i must've mis-typed my 6.1 code...all good now
thanks
sincerley
BONEHEAD!!
001 - PTLE 6.4
Auth Code lost in upgrade? TrevorFWiggins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-30-2010 11:27 PM
Upgrade to Pro Tools 8 (with upgrade dvd) asking for Auth code? (HELP) Mista808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-12-2010 01:40 PM
Need Auth code for downloaded 6.4 upgrade Where??? H. Vincent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-13-2005 05:46 AM
Help!!!! 6.2.2 to 6.4 upgrade!!! auth code!! Pettenatti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-30-2005 01:19 AM
authorization code will not validate bls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-13-2004 02:10 PM
