Old 09-14-2006, 03:28 AM
Tim1 Tim1 is offline
Default DigiTech Support Needed
Mbox & ProTools were working fine until I decided to run Firmware Updater (No internet on this PC). After disconnecting then reconnecting the usb cable as requested all Mbox lights are lit except 48v. When I try to rerun updater I get the message "Error acquiring Mbox in upgrade mode". When I try to run ProTools I get the message "Unable to locate "Digidesign hardware". The connectors look good. Thanks in advance.
Tim
Old 09-14-2006, 10:35 AM
spkguitar's Avatar
Default Re: DigiTech Support Needed
This is the Users Conference; though Digidesign reads and replies to these forums occasionally, if your need direct technical support (which you do), your best bet is to call tech support.
Old 09-14-2006, 10:39 AM
Can I update my firmware w/o being online by downloading the update to a different pc then transferring?
Tim
Old 09-14-2006, 11:08 AM
spkguitar's Avatar
I already told you in your other post , the firmware update has nothing to do with being online. IT is an update between the computer and the Digidesign hardware. The update comes with the version of the software you are using, there is no separate firmware update to download, and it doesn't matter if you are online or not when you run it.
Old 09-15-2006, 06:16 PM
Ok, I finally understand what you're saying about the firmware update. I found an answer from Digidesign that tells me to go to Device Manager and reinstall the firmware driver which sounds good but, when I get there all I see is a blank window, no devices, no nothing! I know you told me to contact DigiSupport, but with my work schedule and their business hours that probably won't happen for a while. Do you think a complete un-reinstall of WinXp and or ProTools would help because everything worked before I messed with it? If anyone has any ideas please let me know.
Thanks
Tim
DigiTech Support, please help Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-27-2007 11:00 AM
DigiTech Support --- HELP!!! claudemorrow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-10-2007 04:39 PM
digitech support, please help.... moon1pulse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-11-2006 03:32 PM
Uh - DigiTech Support? The Dubnicks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-09-2005 03:31 PM
Digitech support please help me CHORDZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-01-2005 11:32 AM
