Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 06-10-2014, 10:40 PM
Leg@cyGuy Leg@cyGuy is offline
Default Fast Track Pro 6.1.10 drivers won't install on Windows 8.1 64bit
For several generations of Windows (XP Pro -> 7 -> 8 -> 8.1) I have had trouble with my Fast Track Pro freezing occasionally and requiring system reboot. So I have tried to keep the drivers up to date in the hope this will eventually be fixed.
But the latest 6.1.10 drivers won't install. I tried uninstalling the previous drivers, but that didn't help, and now NEITHER the 6.1.10 drivers NOR the previous 6.0.7 drivers will install. The error message is just:
"M-Audio Fast Track Pro 6.1.0 (x64) Setup Wizard ended prematurely because of an error. [No kidding!] Your system has not been modified. To install this program at a later time, [blah, blah blah try again useless [bleep][bleep][bleep][bleep][bleep][bleep][bleep][bleep] with no technical details..]"
My system is a new dual 3.84 GHz Acer with 16GB memory, 64-bit Windows 8.1.
So my Fast Track Pro is now completely unusable, and I can't do anything about it!
Please help!!!!
David
Old 06-11-2014, 01:49 PM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Fast Track Pro 6.1.10 drivers won't install on Windows 8.1 64bit
Do you have any AV software that might be preventing the install? Try running CCleaner to clean up any remnants of old software and drivers. When installing the drivers, right click and install as Administrator.
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 06-11-2014, 04:05 PM
Hi Joel,
Thanks for your message!
I uninstalled LightWorks (even though my audio had worked fine after its recent installation). Also ran CCleaner, then rebooted.
Alas, running the Fast Track Pro 6.1.10 installer as Administrator still fails with the same error.
David
Old 06-12-2014, 04:50 PM
Emcha_audio's Avatar
Emcha_audio Emcha_audio is offline
What Joel meant is do you have any Anti-Virus (AV) program that are enabled when installing the drivers? These can sometimes block an installation, or have an effect on the installation of any software that they won't work properly because the AV thought some part of the installation process was suspect when it was not.
Manny.
Old 06-12-2014, 10:16 PM
Hi Manny,
Yes, I did think Joel meant "Audio/Video" by AV software. So I tried disabling my Norton Antivirus and running the installer again (as Administrator).
Still exactly the same problem
Old 06-13-2014, 12:10 AM
At this point, I am strongly suspecting that the root cause of the problem here is the latest 8.1 updates from Microsoft. Has ANYBODY had success installing the 6.1.10 drivers on a 64-bit system with all the latest Win 8.1 updates??
David
Old 06-13-2014, 12:25 AM
The FastTack Pro appears in the Device Manager's list, but has the "Microsoft Audio Driver" (and FTP does NOT appear in the Control Panel's "Manage Audio Devices" list).
I wish I had the driver files as a standard .inf and dlls etc, then I could just use "update driver" to install 6.1.10. But since I only have the "Wizard" executable, which fails every time, I can't try that.
Is there any way I can get an archive of the driver files with the .inf, so I can see if installing that way works??
David
Old 06-13-2014, 12:39 AM
I dug around in the Control Panel's System and Security Action Center, and finally found some more detail about the failed install. It says this:
Source
Driver software installation
Summary
Could not install driver software
Date
‎6/‎12/‎2014 11:37 PM
Status
Not reported
Description
Windows could not copy all of the files needed to install this device driver software. This sometimes happens when the driver software was not designed for this version of Windows.
Problem signature
Problem Event Name: PnPDriverImportError
Architecture: x64
Win32 error: 0000054F
Inf name: MAudioFastTrackPro.inf
Driver Package hash: e19391161e246cc5662e80caf597db8691d94354
OS Version: 6.3.9600.2.0.0.768.101
Locale ID: 1033
Old 06-13-2014, 08:26 AM
JoelG's Avatar
Hopefully someone will post with success/fail info for you. The driver is supposed to work with 8.1, but I'm not sure about 8.1, update 1 (man MS need to change there versioning!). Had it been working properly before the latest updates, or was this a first install on a new computer?
Joel
Jame Space:
Home:
Rig:
Old 06-13-2014, 10:56 AM
6.0.7 had been working on 8.1, but with the usual intermittent freezing requiring a reboot. Everything went south when I tried to install 6.1.10. That failed, so I tried uninstalling 6.0.7, then 6.1.10 install still failed, then 6.0.7 re-install failed, so now I'm left with nothing...
David
Intall Pro Tools LE 8.0.0 windows 7 64bit install csababylon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2013 01:33 AM
M-Box 2 Drivers 8.0.4 Windows 7 64bit problems Caatalyst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-06-2011 03:11 PM
Windows 7 64Bit Audio Drivers (Beta) for Pro Tools LE 8.0.3 philip888 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 92 02-03-2010 03:16 AM
