Old 05-25-2013, 10:10 AM
just Doug just Doug is offline
Default Digitest Failure- HD Core- What should I do?
Just bought a used PCI HD Core card. Failed digitest- only one item in the results:
TDM-II Memoy Test (PIO A Pge1) DSP E : Failed -
Fail @ address 8395933; expected: -1864136, got: -81560.
Any input as to how to proceed greatly appreciated. Have an uncle that can handle the repairs- one of his duties at his workplace- if I can tell him what to repair/replace...
Thanks,
Doug
Old 05-25-2013, 12:52 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Digitest Failure- HD Core- What should I do?
Thanks,
Doug
Chances of repairing this is almost none! It's small format components and impossible to replace without very specialist working inviroment and tools.
The fault is the memory on chip 5. I've had this fault on prcess cards and they still work, but some plugins that open on that chip will not function correctly and make noises etc.
Can't you return it?
I think Avid may do a trade in repair/replace, but not sure if it needs to be registered etc
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-25-2013, 02:30 PM
Suppose I could just return it, but thought I'd check here for input first. For $150, I might just keep it if it's usable as is.
Can I disable the faulty processor somehow..?
Old 05-26-2013, 02:34 PM
crizdee's Avatar
Only way to do so is with pro tools open just click on chip 5 And it will be disabled and no plugins will open on that chip.
Try running a session first and load up all the chips and see what happens?
I found it was only plugins that use ram that would have trouble using the chips with faulty ram. Delay plugins and some big reverb plugs etc. Most other processing type plugins would open fine.
Chris
Producer, Engineer,
www.ukmastering.com
Digitest failure Toto2004 Pro Tools 10 3 05-03-2014 11:36 AM
Can someone advise how serious my core digitest failure is bukman Pro Tools TDM Systems (Mac) 5 11-05-2009 11:55 AM
Digitest failure rubberlugs Pro Tools TDM Systems (Mac) 3 02-18-2005 05:15 AM
Digitest failure - HD2 Core card GL Pro Tools TDM Systems (Mac) 5 01-14-2003 12:41 AM
Digitest failure gitarrcarl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-18-2001 05:51 AM
