Old 10-20-2011, 02:08 PM
evankertman evankertman is offline
Default Pro Tools 9 killed my Garageband
Hello,
So I recently downloaded PT9 to my macbook pro with lion, but now my Garageband (which I use to quickly record acoustic demos with the onboard mic) won't work or respond to anything. Any idea how I can have them both work? They used to back on my old macbook with PT7...
Old 10-20-2011, 03:29 PM
paulrgmusic paulrgmusic is offline
Default Re: Pro Tools 9 killed my Garageband
Yes. There's a Digidesign driver which is installed which kills Garageband. The driver can be safely removed as long as your interface isn't a 002 if I remember correctly. I'll have a look around to see which one it is.
Paul
2011 27" iMac
3.4 GHz i7
12GB RAM
500GB G-Drive Mini (FW audio drive)
Mac OS X 10.7.3 (Lion)
Pro Tools 10.0.1
Mbox 2 Pro (connected by FW)
Old 10-20-2011, 03:38 PM
Hi again
The name of the driver is:
DigiDioMidiDriver
Its only purpose is to control the physical MIDI ports on the 002 and 003 interfaces. If you don't use a 002 or 003 you can safely remove it. This has been confirmed by DigiTechSupt here.
http://duc.avid.com/showthread.php?t=267195
Paul
2011 27" iMac
3.4 GHz i7
12GB RAM
Pro Tools 10.0.1
Old 10-21-2011, 07:23 PM
Excellent, thank you!
VST 2 RTAS Wrapper -KILLED PRO TOOLS - HELP PLEASE IntelDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 10-29-2014 12:01 AM
Pro Tools Update 9.0.5 Help! Midi Killed edisonmusic Pro Tools TDM Systems (Mac) 13 09-30-2011 03:03 PM
Acronis Killed My Pro Tools Glitch Magnet Windows 19 08-22-2011 04:48 PM
Pro Tools Killed Garageband Tyler Routson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-08-2007 11:40 PM
Pro Tools killed by AOL Conscious Structure Pro Tools TDM Systems (Mac) 14 04-03-2001 08:51 AM
