Old 04-17-2004, 12:36 AM
Jbeats Jbeats is offline
Default Midi and Sound Dump
I recently purchased the digi 002. I thought my set up was finally starting to get full. But I just found out that some of my equipment will be "gone" soon. So I need to know is it possible to do a midi dump w/sounds from a sound module into pro-tools? Then trigger the sounds with a midi keyboard? Any help or suggestions would be a life saver. Thanks in Advance.
-J-
Old 04-17-2004, 08:58 AM
mindnoise mindnoise is offline
Default Re: Midi and Sound Dump
You can SYS-EX dump the sounds aka "set of control parameters" to PT from your synth.
But these data can only sent back to be interpreted into sound by you synth, so you have no way playing these dumped sounds via PT alone.
Only way is to sample the instruments from your synth and use a softsampler to trigger these sounds... if have no work else to do for the next two years or so and all the midi parameter controlling will become impossible.
Better not sell your equipment, you´ll regret it sooner or later.
regs
last: PT11.3.1
Midi Dump Dionne005 MIDI 1 04-20-2013 12:26 AM
Midi Dump question.. Captain_Pants 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-31-2002 07:03 AM
Midi Data Dump Andy Sneap Tips & Tricks 14 06-04-2002 10:44 AM
midi dump devee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-02-2001 03:14 AM
midi sample dump from laptop flymax MIDI 0 02-12-2001 01:00 PM
