Old 11-28-2019, 03:24 PM
abt abt is offline
Default Kontakt send MIDI to outside world only works sometimes
I'm having a problem with Kontakt and the "send midi to outside world\script generated note" function. I can't record the output midi from Kontakt to a new track.
I've only noticed this problem with PT 2019.10, and if I switch between Kontakt 5 and 6 the problem remains.
I couldn't get it to work so I created a test session and set it up in the usual way, it didn't work. I closed and reopened the test session and it worked straight away so I though that restarting the session must fix it. I didn't and now I can't get it to work at all.
Any help much appreciated.
ProTools 8.0.4 doesn't send MIDI to Yamaha S90 ES; midi out ports [Emulated] bbirney Pro Tools M-Powered (Win) 8 05-19-2018 06:58 PM
How to send MIDI out of Avid 16 io to external MIDI device? IceOnTitan Pro Tools HDX & HD Native Systems (Mac) 2 02-28-2016 09:45 PM
is MIDI better in the new LE world? healer MIDI 0 01-12-2007 02:06 PM
New to the Midi World letsjam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-06-2003 11:18 AM
Digidesign *COULD* have a World Class Midi/Audio application!!!! Lee Blaske Pro Tools TDM Systems (Mac) 27 12-13-1999 09:37 AM
