structure free stops passing audio
I'm having a recurring problem with Structure free. When opening a session structure free stops passing audio. Manaully triggering from the plugin's graphic keyboard works, but playback from the midi data does not. Duplicating the instrument track fixes the problem. The new track passes audio. Not a crippling bug, but annoying for sure...
Has anyone else had this problem? PTHD8.0cs3 OS 10.5.6 macpro quad 2.6 5gb ram Thanks, |
Re: structure free stops passing audio
Can you verify that the MIDI Out tab of the Instrument track is actually set to the correct Structure instance and MIDI channel?
Do you move your plug-ins around by dragging or option-dragging to a new slot? That can often cause problems like this with VI's. |
Thanks for the reply... |
Instrument Track View |
Ampeg SVX 1.1.3 stops passing audio | Dizzi45Z | Pro Tools TDM Systems (Mac) | 25 | 07-30-2012 02:08 AM |
Left Channel stops passing audio | montezuma | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-07-2010 07:13 AM |
Structure Free: Drag a PT audio region in | DaveSB | Virtual Instruments | 1 | 10-07-2007 06:04 PM |
Waves IR-L stops passing audio??? | SHIRK | Pro Tools TDM Systems (Mac) | 3 | 08-30-2006 08:02 PM |
core audio conects , but no audio passing threw | audiomania | Pro Tools TDM Systems (Mac) | 2 | 08-23-2006 07:41 AM |
