Old 05-24-2008, 03:44 PM
Swivelable Swivelable is offline
Default A valid installation of Pro Tools could not be found
I know this problem has ben discussed before, but I can't find it in DUC or the FAQ & Troubleshooting Guide.
PT 7.4 runs fine on my iMac 2.8Ghz OS 10.4.10.
But I cannot upgrade, and the Tech Support Utility comes up with the same error.
Why would my once valid installation become unrecognizable as such?
And if it's not recognized as valid, why does it function as valid?
Is there anything short of a total reinstall that will fix this? (which for me would mean installing 7.3 to use my upgrade for 7.4)
Is it even necessary to fix if I don't mind mising the mid level upgrades?
Thanks for any input
Breathing with You
Old 05-24-2008, 04:04 PM
Phil Ogden Phil Ogden is offline
Default Re: A valid installation of Pro Tools could not be found
The usual reason for this error is that PT has been moved from it's default install location. Move it back and you should be good to go.
http://www.myspace.com/philogg
Old 05-24-2008, 04:36 PM
I love it!
I amended my PT folder with "7.4" so I don't have to dig too deep to keep up with each app's version.
Deleting those 3 digits made my PT valid again. Much simpler than reinstalling!
Muchly appreciated Phil
Breathing with You
This Updater cannot locate a valid Pro Tools installation on your system DrNO Windows 8 03-26-2013 05:40 PM
This updated cannot locate a valid pro tools installation on your system shotgunndunn macOS 1 12-12-2011 04:06 PM
Pro Tools 8.05 upgrade cannot find a valid installation dickcee Pro Tools M-Powered (Win) 0 03-15-2011 01:22 PM
Cannot Find a Valid Installation of Pro Tools On My Comp??? octopad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 10-30-2010 10:31 AM
cs10 - not a valid installation of pro tools 7.4 Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-06-2009 08:15 PM
