Old 02-09-2008, 06:52 PM
Jesse1 Jesse1 is offline
Default Error 6085 and 6088
Any time I open a PT session and attempt playback, record, or bounce to disk I get 1 of 2 errors repeatedly. I'm running 002 with LE 7.3 w/ 7.3.1 update.
1.)The audio device buffer underflowed. If this occurs frequently, try increasing the "H/W Buffer size" in the playback engine panel or remove other devices from the audio firewire bus. (-6085)
2.)The operating held off interupts for too long. If this occurs frequently, try increasing the "H/W Buffer Size" in the playback engine panel. (-6088)
I have been having this issue for some time now.. I've tried a few troubleshooting steps to the best of my abilities. Running dry with ideas at this point. So far I have followed the optimizing steps through the setup guide that came with the 002 and the optimizing steps through the setup thread on here.
I've run the system module through SiSoftware Sandra...
Comments on report: Error message (-6085) and (-6088)
<<< Computer Overview >>>
< System >
Host Name: HOME-6C24A18C68
User: Fuse
Workgroup: WORKGROUP
< Processor >
Model: Intel(R) Core(TM)2 Quad CPU Q6600 @
2.40GHz
Speed: 2.40GHz
Cores per Processor: 4 Unit(s)
Threads per Core: 1 Unit(s)
Type: Quad-Core
Internal Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way,
Inclusive, 64 byte line size
L2 On-board Cache: 2x 4MB, ECC, Synchronous, ATC, 16-way,
Inclusive, 64 byte line size, 2 threads
sharing
< System >
System: System manufacturer P5K-E
Mainboard: ASUSTeK Computer INC. P5K-E
Bus(es): ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support: 1 Processor(s)
Multi-Processor Advanced PIC (:Yes
System BIOS: American Megatrends Inc. 8.12
Total Memory: 3.25GB DDR3
< Chipset 1 >
Model: ASUS (Bearlake) Processor to I/O Controller
Front Side Bus Speed: 4x 267MHz (1.07GHz)
Total Memory: 23.25GB DDR3
Memory Bus Speed: 2x 401MHz (802MHz)
< Video System >
Desktop Monitors/Panels: 2
Monitor/Panel: Plug and Play Monitor
Adapter: ATI Radeon HD 2400 PRO
Imaging Device: Logitech QuickCam Communicate STX
< Physical Storage Devices >
ST3500320AS 500GB (SATA150, NC:465.76GB (C:)
ST325062 0A 250GB (SCSI100, SC:232.89GB (D:)
HL-DT-ST DVDRAM GSA-H62L (SATA:N/A (E:)
Generic DVD-ROM (SCSI, SCSI-2,:230.28MB (F:)
< Logical Storage Devices >
Hard Disk (D:): 232.88GB (222.33GB, 95% Free Space) (NTFS) @
ST325062 0A 250GB (SCSI100, SCSI-4, 16MB
Cache)
Audio Drive (C:): 465.75GB (290.30GB, 62% Free Space) (NTFS) @
ST3500320AS 500GB (SATA150, NCQ)
CD-ROM/DVD (E:): N/A @ HL-DT-ST DVDRAM GSA-H62L (SATA150, 48x
CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB
Cache)
FORGE80 (F:): 230.28MB (CDFS) @ Generic DVD-ROM (SCSI, SCSI-
2, 32x CD-R, 4x DVD-R, 512kB Cache)
3.5" 1.44MB (A:): N/A @ ST3500320AS 500GB (SATA150, NCQ)
< Peripherals >
Serial/Parallel Port(s): 1 COM / 0 LPT
USB Controller/Hub: Intel(R) ICH9 Family USB Universal Host
Controller - 2934
Controller - 2935
Controller - 2936
Controller - 2937
Controller - 2938
Controller - 2939
USB Controller/Hub: Intel(R) ICH9 Family USB2 Enhanced Host
Controller - 293A
Controller - 293C
USB Controller/Hub: USB Root Hub
USB Controller/Hub: USB Composite Device
FireWire/1394 Controller/Hub: OHCI Compliant IEEE 1394 Host Controller
Keyboard: Logitech PS/2 Keyboard
Keyboard: Logitech HID-Compliant Keyboard
Mouse: Logitech HID-compliant Cordless Mouse
Human Interface: HID-compliant consumer control device
Human Interface: HID-compliant device
Human Interface: USB Human Interface Device
< Power Management >
Mains (AC) Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP (2002) Professional
5.01.2600 (Service Pack 2)
Platform Compliance: Win32 x86
< Network Services >
Adapter: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet
Controller
Old 02-10-2008, 10:47 AM
DMARKETTE DMARKETTE is offline
Default Re: Error 6085 and 6088
are you ready? I know this fix...disable the wireless feature on your laptop (assuming you have a laptop)
for me thats all I had to do? the push of a button
good luck
D
Old 02-10-2008, 02:18 PM
Sorry no laptop... I do on the other hand have wireless capabilities. I uninstalled the WIFI and tried Pro Tools again. Same issue.
Old 02-11-2008, 01:41 PM
Seems like since I posted my issue a couple days ago, my issue with the 2 imparticular errors has been happening more often. To the point now where I am unable to do anything. Due to this issue making me unable to run pro tools, I am out of commision till the issue is resolved. I've run out of ideas and resources. If I could have some form of resolution that would be greatly appreciated.
Old 02-13-2008, 06:11 PM
John Tisdale John Tisdale is offline
I've been having exactly the same problem and have been for days. It's gotten so bad that I get one of these errors every few minutes and can do nothing. If I set the HW buffer size high, it errors out and tells me to set it lower. If I set it low, it errors out and tells me to set it higher. No matter which setting I try, it errors out and tells me to set it either higher or lower.
I just removed a USB LinkSys wireless receiver I installed about the time my problems began a week ago and my system seems to have returned to normal.
Hope this helps...
Firewire Problem !! Error -6088, -6085 Help! tioted765 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-22-2011 05:41 PM
6085 6088 error T666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-18-2009 07:49 PM
6085 and 6088 error track dropouts Mascola24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-03-2009 05:44 AM
continous 6085 & 6088 Error Messages in PT8 H-eleven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-16-2009 08:34 AM
Repeated -6085 and - 6088 error messages upon record JrockManchester 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-03-2009 08:16 AM
