Problems with PTLE? Post your configuration here......
I'm a new user to Protools. After a first attempt at trying to record some guitar riffs through Input 1 on the Mbox2, I can't seem to get any audio playback from ProTools 7.3, neither can i hear what i'm currently playing through the computer speakers either. Got any idea's? Here are my computer specs:
SiSoftware Sandra System Host Name : User : Administrator Workgroup : Processor Model : AMD Athlon(tm) 64 Processor 3500+ Speed : 2.21GHz Model Number : 3500 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size System System : System manufacturer System Product Name Mainboard : ASUSTeK Computer INC. A8N-E Bus(es) : PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : 1 Processor(s) Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Phoenix Technologies, LTD ASUS A8N-E ACPI BIOS Revision 1008 Total Memory : 1GB DDR-SDRAM Chipset 1 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1005MHz (2010MHz data rate) Total Memory : 1GB DDR-SDRAM Memory Bus Speed : 2x 201MHz (402MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce 6800 GS Physical Storage Devices ST3300831AS (ATA) : 279GB (C:) (D:) Logical Storage Devices WINDOWS (C:) : 20GB (122MB, 1% Free Space) (NTFS) @ ST3300831AS (ATA) ANDROO (D:) : 260GB (133GB, 51% Free Space) (NTFS) @ ST3300831AS (ATA) Pro Tools 7.3.1 (E:) : 558MB (CDFS) CD-ROM/DVD (F:) : N/A 3.5" 1.44MB (A:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : Digidesign Mbox 2 Firmware Updater Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : PS/2 Compatible Mouse MultiMedia Device(s) Device : NVIDIA(R) nForce(TM) MIDI UART Device : Standard Game Port Device : NVIDIA(R) nForce(TM) Audio Codec Interface Device : Sound Blaster Audigy Printers and Faxes Model : Microsoft Office Document Image Writer Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Network Services Network Drivers Enabled : No Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: Problems with PTLE? Post your configuration here......
You need to be monitoring the audio from the MBox2, not from the speakers connected to your computer.
Thanks for your help, excuse my igorance.
what kind of cable is used to connect speakers to the Mbox? |
Problems with PTLE? Post your configuration here.. | DJ John | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-28-2007 10:06 AM |
Problems with PTLE? Post your configuration he | krsongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-28-2007 09:59 AM |
Problems with PTLE? Post your configuration here.. | p3tch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-28-2007 09:46 AM |
Problems with PTLE? Post your configuration here.. | Digi ETS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1041 | 08-28-2007 09:39 AM |
Problems with PTLE? Post your configuration here.. | Gaba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-23-2007 08:01 AM |
