Old 11-14-2010, 02:48 PM
mattytoldhatty mattytoldhatty is offline
Default White Noise Bursts in PT9
Am I first on the block with random white noise bursts? I monitor quietly so no damage except to my enthusiasm for switching PT on. I'm running W7 64bit professional on an ASUS P6X58D E with 6g of OCZ 1600 and WD 1Tb Black audio and Vertex 60g ssd system. 003 factory at the front. I initially spent a day wrestling the install then went for a clean OS reinstall and full PT9 on that.
Anyone else??
Old 11-14-2010, 08:42 PM
Default Re: White Noise Bursts in PT9
Working fine here. Trashing prefs can't hurt. Also, check for updated drivers for everything on your system(starting with the 003 drivers). You may need to update ilok and midi drivers as well(but I wouldn't think those would cause noise blasts).
Strebor24 Strebor24 is offline
Perhaps the PT9 forum?
Sounds like this happened with the first 8 update and got fixed.
Shuttle PC, XP Home SP 3, Core 2 duo 3.16 GHz, 4gb PC6400, 500gb SATA 3G HD, Mbox2 pro., Pro Tools 8.
Old 11-14-2010, 09:58 PM
TOM@METRO's Avatar
Early 8.0.3 was the last time I've seen this. Are you sure it's not a demo plug-in warning?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-15-2010, 01:43 AM
andre67 andre67 is offline
Lightbulb Re: White Noise Bursts in PT9
Please supply us with links to the updated new audio and midi drivers........as this site is not the Easiest to find stuff.......
Old 11-15-2010, 05:54 AM
finding this took about 30 seconds
http://avid.custkb.com/avid/app/self...p?DocId=379411
Old 11-15-2010, 07:17 AM
Thanks for the responses guys. I only put PT9 on the machine on Friday. Clean W7 install with nothing else on the machine. I put the new 003 drivers on as per the instructions. I've got the updated factory plug ins ....... only one instance of those looked a bit iffy as it installed ... Hybrid 1.5.4 update. I'll trash the prefs as you suggest and take that plug off. Funny thing I recall is that I tried to install Melodyne essential and it installed and was seen by PT, but when you open it in a track it doesn't see the waveform or the bar grids ... its blank. Since then the WNBs. I might just start again, anyway I'll post the outcome in case it helps someone else. (I've got a ticket out with Melodyne so something may come of that)
Thanks again
Matt
Old 11-15-2010, 09:01 AM
Back in business. I guess it was in the prefs ... who knows. Thanks again for your responses
Old 11-15-2010, 05:35 PM
WOOHOO!! I love it when a plan comes together. BTW, Melodyne Editor is working well in PT9.
White noise bursts gemada Pro Tools SE and Essential (Win) 6 06-20-2011 12:51 PM
PT9 White Noise Bursts therecordinghouse Pro Tools 9 1 11-19-2010 10:12 AM
white noise bursts deedpartle Pro Tools TDM Systems (Mac) 9 08-26-2009 04:22 AM
Bursts of white noise Danielle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 01-24-2004 06:30 AM
White Noise Bursts with 6.1.1 LE M BOX jamieoliver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-03-2003 10:39 AM
