Master fader or not?
Does it matter to use a Master fader to bounce a track down to a stereo track before mastering? Is it best to use a MASTER FADER or NOt,, or does it matter?
Re: Master fader or not?
The reason why I am asking is when I put a master faer on i got the meter going into the red just a few times but when bouncing down with aout a Master Faderno meters on any of the tracks showed any red
That's the exact reason I now USE a master fader on every project. You need to avoid clipping and its pretty easy to hit clipping on the master. If you don't use a master track, that clipping still exists(you just can't see it).
Even though your individual channels or plug-ins may not be clipping, You may get overs when the channels are summed to your master. If it's just occasional, you can lower the master fader a couple dB which will rectify the problem.
In the future, you can record using lower levels or trim all your channels before mixing if they are hot because there is no real advantage to recording or mixing on a 24 bit platform where any channels or the summed mix is hitting near full scale. Yellow is the new red. |
With 144 dB of dynamic range in a 24 bit system you have plenty of room to spare when it comes to the noise floor.
Consider how audio signals sum and imagine 30-40 hot audio tracks, add a few VI's that are cranked up to blend, and that mix bus is now slamming hot, crunchy and clipped. Personally, if I need to pull the master down more than 4-5db to stop clipping, I will lower all my audio and VI tracks by 3-5db(old gain staging habit)
Interesting thread and once again lots of good info from the members here.
I recently read of someone advocating using 2 Master Faders in their set-up. Does anyone do this?.... would there be any advantage in doing this? |
Some use a master fader to control the input of their mix buss aux, but I've never found any reason to do it that way. I use 1 master fader, and it's always sitting at unity gain.
While I don't sweat meters at 24 bit like I did at 16 or 20, I am still not going to sign on with being cavalier about not being mindful of good practices in gain staging. |
Basic Gain Structure Fader/Master Fader Question | acmost | Pro Tools TDM Systems (Mac) | 1 | 05-16-2011 05:36 AM |
Fixing Clipping in Master in Master Fader | pakobo7 | Pro Tools M-Powered (Win) | 10 | 09-16-2006 10:53 AM |
Master Fader 6.7 Master Fader issues | Bogner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2005 07:42 AM |
DIGI: Will it ever be possible to implement Pre-Fader Inserts on the Master Fader? | Ricky Cobble | Pro Tools TDM Systems (Mac) | 5 | 05-05-2003 04:47 AM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
