Old 10-08-2000, 05:29 AM
Guest
Posts: n/a
Default Glyph seagate 9gb won\'t Mount?
Please help my seagate 9gb hard drive wont mount and it also makes a grinding noise. Does anyone know of a Data Recovery solution that won't leave me homeless (financialy).
Any and all of your tips are greatly appreciated....
Thanks Marty M
Old 10-12-2000, 12:03 AM
Sticks1 Sticks1 is offline
Default Re: Glyph seagate 9gb won\'t Mount?
I'm not sure about the grinding noise but check your cable for any crossed or bent pins. I had this problem recently and discovered a couple of bent ones. The drive would show up durring a scan but no icon would appear on my desktop.
Sticks
Old 10-12-2000, 12:50 AM
Ang1970 Ang1970 is offline
Same goes for oxidized pins. Reseat everything (or be totally anal and clean all the pins with an approved solvent).
Is deoxit recommended for this type of thing?
I have also run into bad cables which started out fine but then frayed internally over time. Swap check.
Angelo Quaglia
AQ Productions
Cheers,
Angelo Quaglia
Glyph or Seagate hard drive with PTv8? Mike Teslow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-25-2009 11:30 AM
LCD mount? Where do I buy the low profile mount from demo? sonicboost VENUE Live Sound Systems 6 08-28-2008 07:46 AM
I can't get the Glyph Netdrive to mount...input needed Pat Thrall Pro Tools TDM Systems (Mac) 0 03-01-2003 10:00 AM
How to mount a Firewire Glyph drive? Polaris Pro Tools TDM Systems (Mac) 3 08-10-2001 01:29 AM
How to mount a Firewire Glyph drive ashdot Storage Subsystems 0 08-10-2001 01:18 AM
