Old 12-04-1999, 11:11 PM
Guest
Posts: n/a
Default Impirical Labs Distressor as tape / valve simulator on drums, tips?
Drums direct to PT, no tape (hold that thought). I have realised that my 2 x distressors may come in handy as they have a fattening distortion / tape simulation FX.
Any sugestions for settings ???
Old 12-05-1999, 11:32 AM
Dead Space Dead Space is offline
Default Re: Impirical Labs Distressor as tape / valve simulator on drums, tips?
I don't usually compress drums to "tape" (just a personal preference). Unless you're certain of the compression you want to use, try the 1:1 ratio and Dist 2 or 3. Then just drive 'em until they just tickle the red clip light. I've also found that using an old Neve or Calrec mic pre adds some natural compression and smoothness.
aj
[This message has been edited by Dead Space (edited 12-05-99).]
Old 12-24-1999, 01:37 AM
El Guapo El Guapo is offline
I've also got the distressors and mostly use them on Bass. Also just got the McDSP which has pre-sets for distressor. Just started using it and it made a weak snare POP out using a "distressor" like pre-set.
Old 12-24-1999, 05:38 AM
Jules Jules is offline
Thanks, I think after your answer and some on another newsgroup, I will stick to using them on room mic's and other stuff and not use em on the close drum mics, too risky!!
Have a good holliday all!
Jules
Jules
London, UK
Come hang with us here!
www.gearslutz.com
Old 12-24-1999, 09:20 PM
Mick F. Cantarella Mick F. Cantarella is offline
I've used the Distressors on Kick and Snare with good results. Sure, why not?
-Mick
PT III TDM 4.3.1, DAE 3.4, Mac9600/system 8.1
Old 12-24-1999, 10:42 PM
Steve MacMillan Steve MacMillan is offline
Catching a vibe is so important while tracking with musicians, so I wouldn't be afraid to use compression to tape if the music calls for it. If you are afriad of locking yourself into something too radical then print additional flat safety tracks or use the compression on the playback side.
sm
macmandigital.com
Old 12-26-1999, 05:52 AM
I've got a Tube Tech reserved for kick & Snare!
I read a post on the newsgroup rec.audio.pro, that while you might whip out low 'bonk' frequencys on drums to analog, mabey it's a good idea to chill out taking too much of them away while going to digital....
Almost 40 now, I had gotten close to getting bass end on analog perfect....Now I discover thats supposed to be the hardest thing to get sounding good on digital!!!
Age 90 I will say "I've finaly got it!" then drop dead.
Bass, the final frontier! "Something wonderfull is going to happen" (movie 2010)
Jules
Jules
London, UK
www.gearslutz.com
Old 01-03-2000, 02:02 PM
Studio Dweller Studio Dweller is offline
Just this weekend, I got one of my best bass sounds. The signal chain was very simple, Steinberger bass w/Bartolini pickups directly into the the hi-z input on a Peavey VMP-2 preamp into a Distressor and then to the 888|24. The Distressor was in "opto" mode, with no more than 3 db of gain reduction and the "Dist 3" engaged. A very full, round bass sound. Nothing thin about it. I too come from an analog background, but this bass sound holds up to anything I've gotten out of my analog recordings.
Larry Bentley
Cellar Dweller Productions
www.cellardweller.com
Larry
PT 2019.12 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 01-04-2000, 07:19 PM
Well alright! I've promoted the Joe Meeks to room duty so the distressors are free for bass!
Jules
Jules
London, UK
www.gearslutz.com
looking for a free RTAS Tape Simulator oplatner Virtual Instruments 9 11-07-2012 07:08 PM
Distorted / Tape / Valve Amp Vocals Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-21-2008 08:59 AM
Empirical Labs Distressor... Buy or No Buy? Jsswtpmp182 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-22-2006 08:32 PM
DuY Tape / Valve experiences? Felix Tips & Tricks 2 02-14-2001 01:52 AM
duy valve/tape fidelman Pro Tools TDM Systems (Mac) 4 01-24-2000 05:37 PM
