Old 10-25-1999, 02:09 PM
Guest
Posts: n/a
Default Planning machine room for noisey computer / bit 3, advice please
So,
Geffin extend it?
Good product?
Only product?
For a dual monitor set up too?
My situation, there ain't no window on the machine room so the interfaces and I geuss the USD have to be in with me in the control room.(I prefer that anyway for tweaking)
I have Pro Control too (come back!) The eithernet cable I was suplied with seems fairly long....can I extend that too?
I had hoped to clock all this and some other stuff via an Ardsync unit one day in the future.
Is all the above happy a long way from the computer / bit 3 chassis?
What are the limits / risks?
Thanks in advance.
Jules
Old 10-26-1999, 08:45 AM
Borgbilly Borgbilly is offline
Default Re: Planning machine room for noisey computer / bit 3, advice please
Hey Jules.
Here is a product that may help you out - it sure did the trick for me! Custom Consoles of Nashville make a rack enclosure called the Isobox. It is a very well constructed unit and provides very good isolation for noisey fans and hard drives. Here's their web address.
http://custom-consoles.com/
Todd Beeten is a great guy to work with and will custom design just about any type of enclosure you could think of. Check out the custom console he built for my ProControl with an Isobox enclosure for the right hand bay. Just follow the links to ProControl - mine is the black lacquer finish with the big red iso booth behind it.
This is a much better answer than trying to put your computer and drives in a displaced machine room. If you don't believe me, just wait till you have to authorize PT and about two dozen plugs from floppies with your computer in another room! What's more, the Isobox has a plexiglass front door so you can look at the indicators on your interfaces and drives. Get one with casters and you can roll it where ever you need it. All you need is a long ADB/USB cable, long monitor cables, and a long ethernet cable. BTW - that ethernet cable can be hundreds of feet long without problems.
Richards Outpost Audio
* Ain't Life Grand?*
Old 10-26-1999, 10:42 AM
digichaos digichaos is offline
an alternative to Geffin (cheeper I think),
try www.networktechinc.com
Old 10-26-1999, 12:47 PM
Guest
Posts: n/a
Thank you both very much.
Jules
Old 10-26-1999, 10:02 PM
drBill drBill is offline
hey borgbilly,
How many dB did the isobox drop the noise floor in your controlroom? Do you have external HD's as well as your computer. This seems like a good idea, but I have yet to talk to anyone who can give me some impiracle data other than "yeah, it really quiets it down". Does the computer or HD's telegraph to the case itself? Can you hear either your computer from inside or the isobox fan at 10 feet? How quiet is it?
Thanks for any info. I'd like to buy one or two, but it's a lot of cash.
drBill
Old 10-28-1999, 12:21 AM
mtoy mtoy is offline
I'm an idiot, I will probably say something stupid during this message. OK, now that I've admitted that, I can tell you something of my experience with the isobox.
First of all, the "studio" is a 17x33 basement.
I have an isobox with three 4U fan cooled computer boxes in it (Mac, Disks, and DSP). These things make a stinking lot of noise (radio shack db meter reads 65 when stuck in front of the rack, nothing else in the room or neighborhhod making noise)
If I close the door, there is no longer enough noise in the studio to read on the cheap radio shack meter ( < 50db ).
At 10 ft away, I can still hear the system noise even with the door closed, so the box isn't magic, but the noise in the room has stopped being my #1 problem when recording things in my "studio".
Even if I had a seperate control room and recording space, I'd still go for the isbox, it is tough to mix with those fans singing to you.
If I had a zillion dollars, my ultimate preference would be for the noisy things to be in another room, but short of that, I could not live without my isobox.
Old 10-28-1999, 03:34 AM
Guest
Posts: n/a
Here's the deal, my rig is set up in a huge flightcase almost 6ft tall. It needs to be ready to wheel in & out at short notice, so Iso boxes are, unfortunatly, a no go.
The new control room is big, I think I will have the 2" in there (for metering) and remote, and then have the PT next to the 2"
but behind screens.
I can also cover the corner it slides into with that accoustic foam grey stuff. That might have to do it.
The machine room might have just become the tape copy room!Perhaps I could put an old G3 in there with some hot swap drive bays and a DATA dat and do back ups on it while I am uploading on the main system.
BTW how far can an interface be from the computer? & the USD?
Jules
Old 11-02-1999, 12:19 PM
fdinthea fdinthea is offline
We've got 4 PT rooms, and we've placed all the equipment in two racks that are located in a separate area outside the rooms. We've wired extensions for ADB, VGA, MIDI (to HUI), printer cables (to MIDI interface and switch boxes), etc. many of which are 30-40 feet in length, and have had no problems. We've had no picture degradation on the VGA monitors, no loss of signal from the ADB line, or anything else. I highly recommend sticking your WGAs (whirring grinding units) outside the room, hook it up and see if it works before spending exorbitant sums on iso boxes, low-noise drives, or cable extender boxes.
Image Resources Film & Video
Encino, CA
818-981-6556
Old 07-11-2000, 05:47 PM
jamerkel jamerkel is offline
I had this same problem. My solution was a bit different. I just made all my drives external via a 15 ft SCSI cable (not cheap), and ran them into a neighboring room through a small removable panel in the wall. It's well isolated from my control room.
I then got an ultraquiet power supply from www.pcpowerandcooling.com. It is very, very quiet. You can't even hear it.
So the only thing making noise is my CPU fan. For this I went out and found a CPU heatsink that was very smooth, and not a lot of edges. It's still audible, but very quiet. I'm still looking for a better solution for this.
With this setup I can easily get to my drives in the other room if I need to, and I can keep 'em really cool with lots of fans. I have the added convenience of access to my CD-ROM and floppy, and all my peripherals cables don't have to run half way around the planet. I can still hear my CPU fan, but it's pretty damn quiet.
Hope this helps!
-=Jeff Merkel=-
Mach 8 Audio
Old 07-12-2000, 01:08 AM
lancehuff lancehuff is offline
What kind of cable do you look for to extend the computer 20-30 feet? Also, what kind of cable do you need to look for to get the monitor extended as well since it's connected to the hard drive? I went to the site www.networktechinc.com and got really confused!!
Thanks
<BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by digichaos:
<HR></BLOCKQUOTE>
PTHD Machine Room Soundtrack2life Pro Tools TDM Systems (Mac) 15 03-10-2011 11:01 AM
Machine Room Temperature D Bag Pro Tools TDM Systems (Mac) 3 02-10-2008 01:03 PM
Should my 192i/o's go in the machine room? everglass Pro Tools TDM Systems (Mac) 0 03-22-2002 06:34 AM
How can I put the computer and hard drives in a machine room. rodrigal Pro Tools TDM Systems (Mac) 6 08-27-2001 04:46 AM
Control PT machine from another room? ponyboy Tips & Tricks 0 10-29-1999 04:07 PM
