How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Additional Resources
Old 03-10-2018, 08:50 AM
Raoul23 Raoul23 is offline
Default OSX 10.9.5 no waves in audiosuite??
Just noticed my waves plugins are not in the audio suite drop down menu??
Waves version installed os 9.3 anyone no how to fix this issue do i have to rescan a folder or something. Ive tried a fresh install but this didnt sort the issue.
Thansk Raoul
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 03-11-2018, 12:30 PM
This is strange as Iíve just checked my Mac Book Pro which is running 10.9.5 and waves are in the audio suite drop down menu?? I used same installer and everything??
Iím confused ??
Raoul Crane
Old 03-12-2018, 03:10 PM
Default Re: OSX 10.9.5 no waves in audiosuite??
Sorted, some how I must have hit donít use audio suite plugins when pro tools first scanned the folder. Waves support pointed me in the right direction
Raoul Crane
Old 03-13-2018, 12:17 PM
Well I thought it was sorted, booted Mac up today and the waves plugins were missing from the audio suite again. I closed PT held shift and reopened PT and guess what?? The box next to donít use audio suite was ticked again. Now I no for a fact I didnít tick it this time. Iíve sent waves support an email hopefully these can help me
Raoul Crane
Old 03-13-2018, 12:22 PM
crizdee's Avatar
crizdee crizdee is offline
That is something you usually do when installing? tried running the installer again?
Chris
Producer, Engineer,
UKmastering E-Mixing & Mastering facility
www.ukmastering.com
PT10.3.6 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2, Quad x2. Manley Vari-Mu, Manley Massive Passive, Solid State Logic VHD, Anthony De Mario ADL600, Grove Tubes ViPre, Tube-Tech CL-1B Aphex 20Z. Hafler TRM active monitoring.
Old 03-13-2018, 12:28 PM
Hi Chris
Run the installer 2 times now, still the same ??
Raoul Crane
Old 03-13-2018, 02:22 PM
crizdee's Avatar
Could try trash prefs
User/Library/Prefs/Waves/pluginFolder_scanView
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-13-2018, 02:39 PM
Thanks Chris Iíll try that
Raoul Crane
Old 03-16-2018, 12:29 PM
That worked Chris, thank you
Raoul Crane
Using Waves Tune in Audiosuite Mark Swanson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-28-2011 11:26 PM
waves overwrite in audiosuite utility 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-03-2009 11:24 AM
Waves V6 can't use "Audiosuite" modulo2008 Pro Tools TDM Systems (Mac) 2 07-09-2008 10:29 AM
Waves AUDIOSUITE latency Darin Donovan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-31-2003 10:11 PM
Waves 3.0 / Audiosuite question daiker Pro Tools TDM Systems (Mac) 11 01-17-2001 01:41 AM
