Old 03-13-2018, 12:47 PM
Sadie Tango Sadie Tango is offline
Default PT 2018 compatibility with Digi 003
I'm still using a Digi 003 which I'm fine with except that it stopped being supported after PT 12.7.1. I'm wondering if anyone has gotten it to work with PT 2018.
Mac Mini late 2012 SSD startup and media drives, Mac OS 10.11.6, Pro Tools 12.7.1, Digi 003, Octopre MK II, Mackie Big Knob, Waves Gold 9, RX6 Advanced
Old 03-13-2018, 02:28 PM
Aaron ANV Aaron ANV is offline
Default Re: PT 2018 compatibility with Digi 003
My Digi 003 is still working excellent here with PT2018. Specs in my signature.
System Details:
iMac (Late 2013 3.1ghz i7 16gb)
MacBook Pro (Mid 2014 2.5ghz i7 16gb)
MacOS 10.13.6
Pro Tools 2018.12
Digi 003 console
Old 03-15-2018, 09:02 AM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Did you need to do anything 'special' to get it working with PT2018.3?
Old 01-04-2019, 09:44 AM
Oli_W Oli_W is offline
I’m on Windows 7, PT2018.3 and digi003 with no new issues since upgrading from PT12.4. One day will probably need to update to Windows10...!
Didn’t need to drop anything special to get it working. 2018.4 didn’t work, but 2018.3 did. Apparently installing 2018.4 over the top might work. Might try 2018.7 too
Old 03-12-2019, 08:44 AM
BeatMakeUfologistic BeatMakeUfologistic is offline
Well but what Driver use in case if 003 has a Driver only for Sierra 10.12. Available ?
Old 03-25-2019, 12:36 AM
justinhill justinhill is offline
I've been using a Digi003 rack+ for a couple of years. I plugged it in after my Focusrite interface died, expecting it to be an emergency measure, but it's been completely reliable. Of course, I don't record on my system at the moment so all I need is the outputs. But I did use the inputs the other day when checking out a used mixing desk I bought and they're fine too, although the input levels seem to be a bit arbitrary.
I have Avid 003 Family 11.1.5 in my System Preferences.
I'm just about to install a major hardware upgrade so the 003 is being retired - but it's served me well in the meantime.
Macbook Pro late 2015, 16GB RAM, High Sierra 10.13.6, Pro Tools Ultimate 2018.12
Update: I just switched over from the Macbook to a Mac Pro 6,1 by cloning the hard drive. The 003 is still working fine as far as I can see.
PT 2018 leaving Digi 002r locked up gcasper Pro Tools 2018 7 03-24-2018 01:15 PM
Reverting from 2018.3 to 2018.1 jamesleonard Pro Tools 2018 11 03-12-2018 05:21 AM
PT 2018 session compatibility with 12.x MikeC Pro Tools 2018 4 03-10-2018 10:05 AM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
digi 002 compatibility in 001 googacky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-14-2003 04:47 PM
