Old 09-14-2005, 10:21 PM
William 2014's Avatar
William 2014 William 2014 is offline
Default MIDI Pitch bend question, please?
Guys , sorry for the dumb question but i can't seem to find the answer anywhere.
Where do i change the pitch bend range in a midi track from a whole tone to
a , whatever other interval?
And speaking of pitch bend:
Is it posible to achieve good results pitch bending brass samples (Kick Ass Brass),
to get some , say, "real" slides the library doesn't have?
I'm having a hard time getting the sound i want, most of the time have to print to audio
and manipulate the waveform to get what i want, but the slides are really something
i can't figure out without doing it in midi.
So will the pitch bend help me in this case ?
Thanx a lot for your time
Hopefully someone will help me, still newbie in PT's Midi...
Will
iMac Intel Core 2 Duo 3.06 GHz / 8 GB RAM ; PT LE 8.04
Old 09-15-2005, 12:50 AM
tha k man tha k man is offline
Default Re: MIDI Pitch bend question, please?
Pitch bend range is set on the Midi instrument, or Virtual Midi instrument if you are using software. Pitch bend will just send midi control data from 0-127 with no pitch being at 64.
Have a look at the software instrument or sampler interface - there will be a pitch bend range
G5 Dual 1.8 /1.5 Gb Ram
OSX 10.4.7
PT LE 7.3 cs1
DIGI 002
Waves Ren
Sony Bundle
Soundtoys-arama
NI Komplete 3
Old 09-15-2005, 09:57 AM
Thanx a lot tha k man, back to Kontakt manual then
Pitch bend in pt's is kinda weird,
have to draw a lot, already a plastic artist
Old 01-30-2006, 07:50 AM
Bezo Bezo is offline
How do you translate Pro Tool's pitch bend measurement? For example, how would a draw a bend for exactly one semitone?
Or do those measurement changed depending on the pitch bend range of the MIDI instrument? If so, does the measurement relate in any way so that I can draw percise bends?
PTLE 8.0.5, Digi 002 Rack
iMac 3.06Hz Intel Core 2 Duo w/8GB RAM, OS 10.6.8
Glyph GT050Q Drives
Old 01-30-2006, 11:53 AM
MunchieLad MunchieLad is offline
set the maximum range on your midi instrument.
drawing the line in protools will bend the note to the maximum at the highest and lowest levels. any other pitch would have to be mathematically figured out or more simply, trial and error.
Edit pitch bend midi data bwandon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2018 08:20 PM
Pro Tools LE 8 Midi Pitch Bend Problem W Sound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-09-2011 02:09 PM
MIDI track not reading pitch bend data? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-11-2009 07:04 PM
MIDI : Pitch Bend Muxlow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-01-2003 09:28 PM
Editing a Midi program sound.... disabling vibrato on the Pitch Bend Bar Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-27-2002 11:06 AM
