Old 02-04-2020, 11:53 PM
mightyduck mightyduck is offline
Default I think I can use my old blue 192 I/O’s
I have an HD native thunderbolt and I think I can use my old blue 192 I/O’s with it. Right?
Best,
mightyduck
MD
Old 02-05-2020, 01:14 AM
lae777 lae777 is offline
Default Re: I think I can use my old blue 192 I/O’s
I'm using mine with a pcie Native card.
I think the thunderbolt box works the same, so you should have no problems.
5,1 Mac Pro, 3.46 GHz Six Core Xeon, 48gb ram, Pro Tools Ultimate 2023.6, HD Native card, Avid 192io interface, Avid 96io, Intensity Pro video card, Radeon HD 7950 graphics card, Mac OS Monterey 12.6.7.
Old 02-05-2020, 03:35 AM
JFreak's Avatar
JFreak JFreak is offline
Yes, the blue DigiDesign-branded interfaces work just fine, but are not supported. It only means if Avid wants to update firmware, the updates only come for the Avid-branded boxes.
Janne
Old 02-05-2020, 01:46 PM
Should work fine as long as you have the right software(HD or Ulimate) and a digilink license (after 12.6HD)
Old 02-06-2020, 02:46 AM
Thanks, guys!
Best,
mightduck
MD
Old 02-09-2020, 07:57 AM
corp corp is offline
Any latency difference?
Old 02-18-2020, 05:23 AM
Default
Not sure exactly what you are talking about, but it seems to me I read that the TDM HD systems had a little bit less roiundtrip latency than the current systems.
Some one should probably chime in with more complete info on this.
Best,
mightyduck
MD
Old 02-18-2020, 10:10 AM
JFreak's Avatar
Yes the old TDM hardware was very slightly faster than the current HDX hardware.
But who cares?
If the realworld latency is less than 10ms there is absolutely no reason why any artist can or cannot perform. Give her a carrot and try again.
Janne
Old 02-20-2020, 02:40 PM
Default
"But who cares?"
Many who don't post on the Avid site.......:roll eyes:
Maybe Avid should rid the HDX card if latency is not an issue and why didn't Avid design around 20ms minimum.......:roll eyes:
My question is more in the direction if third party interfaces have more latency compared to a Avid product.
https://www.audiocheck.net/blindtest...2w.php?time=10
http://www.silcom.com/~aludwig/EARS.htm
Old 02-23-2020, 02:13 AM
"But who cares?"
The issue you are probably going to run into if using anything other than Digidesign or avid hardware is that the pro tools software's ability to compensate for input and output latency [i.e. for punching in, overdubbing, and so forth] only works with the Digi / avid stuff [and I think Lynx has the same spec, too, so they supposedly also work].
So its not so much what converter has a little more or less latency, its about whether or not the converter's latency is the same as what the software will recognize / set to compensate for.
mightyduck
MD
Blue Cat's PatchWork Updated to v1.62, with brand new Light Blue UI Theme bluecataudio AAX Plug-ins 5 01-10-2015 12:41 AM
How do you know if you have a Green, Blue or non Green or Blue Drive [email protected] Pro Tools 10 14 12-25-2013 12:13 AM
Sync-blue and midi-blue with protools 11? John Becool Pro Tools 11 4 09-11-2013 10:28 AM
Blue 192? woof Pro Tools 11 1 06-26-2013 08:03 AM
Blue 192 IO's Soundtrack2life Pro Tools 10 15 10-22-2011 09:28 AM
