Re: ProFire 2626 Line input levels are quite low
double post. sorry
Have any conclusions been made yet?
Also, are the outputs +4 or -10? |
-36dbfs is nowhere near the *normal* range a +4dbu line-level signal should read. Really, all a 2626 owner needs to do is try inputting a +4dbu TRS line-level signal.
________________________ www.PlethoraTone.com PlethoraTone Studio Video Tour At PlethoraTone: Mac Mini M1, Avid Carbon, PSP, Waves Mercury, UAD, Kush, Slate Digital, PA, Melodyne, Antares, Audioease, SoundToys |
Any other 2626 users have this problem or tried sticking a +4dbu signal from a pre or something similar into their unit?
You know, I personally haven't had any problems with my 2626. I've always been able to figure out how to get a good signal in, but I always had the pressure of being in the middle of a session. This probably doesn't help any and I'm sorry. I love my 2626.
-Eric Yeager King Studios |
#16
Thanks Eric - so you've no issues hitting the 2626's line-level AD with a hot signal? Not that you would ever want to, but you can peak PT's channel meters into overload using a 2626 TRS line-level input? That would be the extent of the *test*.
We hope that our current unit is the only one.... M-Audio has shipped me another unit (thank you M-Audio!!), so I'll report back as soon as it arrives.
#17
*awaits reply*
I ordered mine through M-audio's employee program, and its backordered until july =[ |
#18
GREAT NEWS - Just had an outstanding series of calls from Calvin Banks of M-Audio.... what a class act.
The ProFire 2626 as a product line is 100% A-OK - they just verified the TRS signal path and there's no issues with line-level inputs!! My unit's just malfunctioning - but being replaced as I type For anyone who's interested, I'll post the replacement's results later this week.
#19
Nice! Great customer service. Post back with the result.
There seems to be confusion, though. 1: Meters within PT are measured in dbFS not VU 2: Not all devices are calibrated to 0dbu=-18dbFS some devices for HD system might be set to -18dbFS, but other devices? It really varies unit to unit. I got presonus mic-pres connected to my projectmix using lightpipe. The presonus unit's maximum input is +22dbu and its reference level for D/A is 0db=-18dbFS. It's nowhere near 0dbFS within PT, too, but still it's 0db we are trying to keep the signal close to. Remember anything above 0db(FS) within PT will be digitally clipped. That's why they set 0dbu significantly lower than 0dbFS for many gears. Many gears are calibrated so the maximum input level will euqual 0dbFS. If everthing is recorded closed to 0dbFS, the mix will have a lotta distortion. This is exactly what happened to early digital recordings. |
#20
No confusion here Tash - insert the Bomb Factory VU and there's your meter.....
As long as your injecting a sine wave to set levels, you'll have the identical reading on the channel's peak LED meter or the VU. 0 on the peak meters or the BF VU = -18dbfs This is true for MP & LE.
Is the Profire 2626 more stable than Profire Lightbridge? (PT8 or snow leopard?) | tomv-k | Pro Tools M-Powered (Mac) | 5 | 03-09-2012 02:45 PM |
Can't get Profire 2626 input to display | tedthecellist | macOS | 3 | 12-21-2011 11:17 AM |
No MIDI input with ProFire 2626 | andrewkerr | Windows | 2 | 03-30-2011 11:10 PM |
If you have a mac and a profire 2626, could you please help? | theaero | Pro Tools M-Powered (Mac) | 5 | 07-14-2008 01:32 PM |
Mbox-setting input levels w line inputs or s/pdif | peccatte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-22-2003 09:20 PM |
