Mixed Up!
Hey What's up Duc! I have a question for some of you experienced mixers. Can you guys give me a general path of travel when it comes to starting a mix. I am fairley new to mixing, and I kind of need a general guide line on what to start with, and how to navigate through a mix! I know this is a very subjective subject, and I realize that there are probably a million and one ways to go about it, but for a person that is new to mixing, to many options can be overwhelming!
If some of you guys could give me a general idea of how you go about mixing your projects, then that will give me a system to work with, and once I know what I am doing then I can incorporate my own style into the*process. Until then, any help will be appreciated! Thanks very much! |
Re: Mixed Up!
What kind of music are you doing? Generally I'm rough mixing as I'm tracking, so there is no set 'starting point', I just tweak off of the mix that's been happening all along.... but if I'm given a track from someone else just to mix, I usually start with drums and bass and move up from there, but that's just for standard pop/rock stuff, I approach other genres differently.
Re: Mixed Up!
Sorry I left out that little detail! I am doing hip hop, r&b!
Re: Mixed Up!
HI,
general path: http://www.theprojectstudiohandbook.com/directory.htm no matter what genre you´re in, there are some basics to be learned and how they fit together. as long as you don´t master the basics you will get nowhere. the rest comes with practice and experience. regs
last: PT11.3.1 |
what is the mixed ch. ? | lowam16 | Pro Tools M-Powered (Mac) | 0 | 04-16-2007 08:13 PM |
Mixed in the box? | Scott Wood | Post - Surround - Video | 29 | 11-09-2004 10:24 AM |
check out some hip hop mixed entirely in LE (001) | WestPhillySoulzition | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-17-2002 06:14 PM |
Mixed on Digi 001 | Grey Moore | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-25-2001 08:32 AM |
HFS+ & standard mixed...? | Polaris | Pro Tools TDM Systems (Mac) | 2 | 10-28-2000 05:31 PM |
