  #21
Old 12-06-2013, 05:59 AM
KaiXXX KaiXXX is offline
Default Re: Big gang/crowd vocals
I normally go for the "Bruce Swedien"-style Blumlein setup (two figure of eight mics (e.g. 414) in MS configuration. Group of about 5 people (=the band) about one arms length in distance (semicircle or circle). 4-5 passes.
I found it to be important that everybody should shout a bit higher than they would normally do. If everybody is shouting low, it will sound like the crowd is about to fall asleep... higher sounds more energetic. Might record one or two lower passes for variation though.
Also, I really like to add (at least) the lead singer with the normal close micing technique. Just mix it in (not dominating over the crowd). Since the close miced sound is completely different from the stereo-setup, this adds great depth into the crowd-mix! (in reality I first record the lead singer and then the crowd, the lead track is also the guide for the crowd).
I'd really like to hear some more ideas about effects (delay, reverb etc.)
I personally will use a pretty heavy echo and also reverb obviously. I found that "church-type" reverb is not really working for me, rather a medium sized hall or plate...
Might add some Dimension D and/or little microshift (chorus type effects basically).
One plugin I like to use on shout vocals to get variation out of double tracks is Antares Avox Mutator. Just some slight adjustments and it sounds like the singers twin brother (or so...) ;-)
Might also try some distortion (maybe just on some tracks!?) like Decapitator or some guitar amp type plugins or hardware (Sansamp...).
  #22
Old 12-06-2013, 06:06 AM
Here's a track I did a couple of years ago which is kind of similar to comeback kid.... Gang vocals a pretty tight and direct (no arena sound) ;-)
http://www.youtube.com/watch?v=OevWK9oxddA
  #23
Old 07-26-2015, 04:02 PM
AhwatukeeComputerRepair AhwatukeeComputerRepair is offline
I would suggest getting as many people as you can in the room to shout the lyrics. Even if its Girlfriends, Boyfriends, Even you as the mix engineer can go out there and throw your voice in the crowd.
Try to put a small or medium reverb on the crowd after you pan it to the left and right. Try a hard pan and a soft pan then pick which one you like better.
  #24
Old 09-22-2015, 01:01 AM
Andy Gone's Avatar
Andy Gone Andy Gone is offline
I used to use a convolution plugin to create a crowd effect, but really it is much easier to get as much people as possible together and record a couple of takes :) Then you parallel-compress them and voila.
Can I gang 2 MBOXes for more inputs? david kowalski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-02-2008 04:19 PM
hi gang... I just finished up our new web site... georgia Post - Surround - Video 7 08-31-2006 09:33 AM
Post Q #2: How to gang several ProTools? Bokir Post - Surround - Video 6 04-14-2004 02:46 PM
kool and the gang production badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 09-04-2003 05:20 PM
Gang Box Design/Diagram paulpatras General Discussion 0 11-27-2002 09:45 AM
