#2071
Re: Best Core 2 Series Desktops-Results and Specs
the ASUS P5K is very dated at this point. if you can get it then it is a safe and sure way to go. you'll probably have to look at the P45 chipset. i would definitely look at the ASUS mobo's tho. they've proved to be the most reliable/compatible with PTLE IMHO.
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#2072
Thanks for the help Mykhal - I have a lot to read up on over the weekend, that's for sure!
Brian |
#2073
You can check out their website for prices & models, but to really be impressed just call them. These guys know music & they know ProTools. No, I don't work there or anything. I'm just a happy customer. |
#2074
Anyone else have any opinions for this? What about RAM? |
#2075
i'm buildin' systems these days too so feel free to hit me up if you'd like to talk about a build
#2076
Cool - I will let you know - thanks!
bc |
#2077
NZXT LEXA BlackLine Black Steel / Plastic ATX Mid Tower Computer Case - Retail $109.99
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail$129.99 Rosewill RP550V2-S-SL 550W ATX12V v2.01 SLI Ready Power Supply - Retail $57.99 Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X4096-8500C5D - Retail $84.00 2xWestern Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $89.99 LG 22X DVD±R DVD Burner with LightScribe Black SATA Model GH22LS30 - OEM $25.99 Arctic Silver AA-1.75G Thermal Compound - Retail $189.99 $3.99 heres the system I have in my newegg wishlist still need a dual monitor video card but its already up to $781 more expensive then I wanted to spend for a non i7 anyone have any suggestions or comments on this setup?
i7 920, Gigabye ud4p, 12gb OCZ Platinum ddr3 1600, 2x 640gb WD Caviar Black 1x Samsung 120gb SSD
HACKINTOSH Mac OSX 10.8 Pro Tools 10.2 OLD Dverb 1024 - 520 Dverbs 64 - 433 Dverbs NEW Dverb 1024 - 283 64 - 235 |
#2078
It seems to me if you are expecting to get a dual hard drive quad core computer with a good amount of ram without having any components to start off with for less than $800, you are asking for a lot. The problem is, when you start sacrificing the quality of the components to get the price down, you start to compromise the computer.
4-5 years ago the "cheap"computers were running at about $500. With the rate that everything has gone up, I would say that number should be around $700 now, and those computers were always a definite step down from what was available. |
#2079
Hi all,
Working on my first build and definitely learned a ton from all the posts in this forum. It will look about something like this: Intel Q6600 AC Freezer 7 Some P5Q mobo CORSAIR 520HX 520W PSU Nvidea Geforce 8800 GTS video card Corsair Dominator 1066 - 4 gb 2 WD 500 gb hds Comments? For a case, I'm debating between the Antec P-182, Solo and Sonata Elite. Will there be a significant difference between these in terms of noise and airflow? I noticed that the P-182, in contrast to the Sonatas, places the power supply at the bottom of the case. Does this have a significant effect on keeping the case cool? Anybody compared these cases? Recommendations? Also, I'm removing the CPU from my HP desktop. Do I need to buy some Arctic Silver 5 Thermal Compound and reapply some to the CPU and heatsink or can I reuse what's on the CPU? Does the AC heatsink come with preapplied grease? And, finally, have the people with P5Q's had to flash the bios or is the one that's preloaded fine? Thanks! -Yoni |
#2080
anyone give the samsung HD's a shot? Their a tad cheaper wondering if their any good.
i7 Builds - Specs and Results | mykhal c | Windows | 7144 | 04-15-2024 12:10 PM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
