static issuse vinyl>PT10
i am recording vinyl into pro tools via a phono amp into my mbox 2.
it sounds fine when i monitor the vinyl, but when i record enable it introduces massive static, even with the pads enabled and the inputs turned all the way down on the mbox2. what is happening? turntable>ST.RCA>phono-preamp>ST.RCA-Dual TRS>D.I-mbox2>PT10 windows 7 64-bit |
Re: static issuse vinyl>PT10
Could be ground. Are you using a laptop? If yes, try to run it on battery without power-supply connected. If you work with a desktop machine check out the leads you're using to hook up the phono-preamp. Are the leads balanced? If yes cut the ground on one end, re-connect and see how it goes.
A general tip is to remove items one-by-one from your recording chain. If the problem persists after removing a particular piece of gear you know it wasn't the trouble-maker. Continue until you find the source of the trouble. Hope this helps. J.
2010 Dolphin Award for Production / Engineering AVID Certified Instructor |
Mbox 3 issuse!!! please Help | saulreyes87 | Pro Tools 9 | 2 | 12-03-2011 08:51 PM |
Clocking Issuse with 003, any ideas? | gerax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 01-14-2010 07:26 AM |
Noise Issuse | audio1420 | Pro Tools TDM Systems (Win) | 0 | 09-17-2005 06:25 PM |
End of Vinyl ?? | Plastik909 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-28-2005 11:23 AM |
Audio suite Issuse | audio1420 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-04-2004 08:31 AM |
