Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 12-15-2018, 08:35 AM
Jim Morris Jim Morris is offline
Default Application Manager
Does Application Manager work for ANYONE? Why do they keep updating it, if they won't fix it? The troubleshooting guide mentions:
"Not responding ("Authenticating" or "Initializing")
Unable to connect to the Avid servers"
but then gives NO advice on how to fix those issues.
Somebody is asleep at the code wheel....
Old 12-15-2018, 12:04 PM
orvillej orvillej is offline
Default Re: Application Manager
I uninstall it immediately. It's useless.
using PT 2023.9, 24' iMac M1 16GB RAM, Ventura 13.6.1, Apollo Twin interface
Old 12-15-2018, 01:29 PM
It’s awfully poor quality code that might work for a while OK and then will have problems. Should be an automatic uninstall. Kind of what I expect you might get when an outsourcing/third party development company sells a struggling software company on outsourcing development to some low-cost overseas team....
Old 12-15-2018, 01:37 PM
_JJ_ _JJ_ is offline
I also uninstall it immediately, making sure to uncheck the uninstaller itself.
Old 12-16-2018, 10:24 AM
The Weed's Avatar
The Weed The Weed is offline
I use it infrequently to check if any plug-ins need updating, but have it stopped from starting automatically when Windows starts - thanks CCleaner.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-16-2018, 02:04 PM
xrekcor's Avatar
xrekcor xrekcor is offline
never experienced a prob with AM at this stage as it seems to function as expected... is this an issues with particular versions or setups?
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 01-10-2021, 08:27 PM
charleshollins charleshollins is offline
I also faced the same issue. I also uninstalled it as it was not working properly.
Application Manager... Darren Harker Licensing & Accounts 1 09-07-2018 12:16 PM
Application Manager jchan Pro Tools 12 3 11-07-2017 09:13 AM
12.8.1 Not in Application Manager taylor4814 Pro Tools 12 6 08-28-2017 09:54 AM
Can Not Log In To Application Manager MicESanzMusic Pro Tools | Intro Discussion 5 07-02-2017 07:55 AM
