Popping sound every time audio playback is stopped
Apogee One
Any Buffer Size 10.7.2 MBP Just as the title says, getting a click/pop sound every time I stop playback. Anybody else experiencing this? -Chris |
Re: Popping sound every time audio playback is stopped
Open the session holding down the shift key! this will deactivate all plugins, now see if there's a pop. If not then try reactivating the plugins one at a time till you find the cause. Chris
Yep, on some sessions it is a pest. Don't know what causes it. Digital spike every time you hit the playback button to stop. This is on HD3 PT10 HD Mac Pro, Apogee Rosetta, 2 192 digital, 1 96I/Oi and big ben. Had it on previous version of PT too. |
Same issue, even without any plugins. Rosetta 800 here, seems to be the common variable.
Yea it is happening to me without any plugins open. It happened on Pro Tools 9 all of the time but I assumed it had something to do with it being a beta application.
Yup, same here.
All plugs disabled. It's like static build-up in my dryer. I wonder if Bounce could make a plug-in. |
I'm inclined to think this is an Apogee driver issue
I think it has to do with how pt does an auto fade when playback is stopped
If I'm playing back a track and hit a memory location for the start of the song. Where there isn't any sound or (ie before any clips start) it pops. if I move to an open space (no clips Blank space) and hit the same the same memory location then no pop So I think if the playback buffers have audio running through and playback is stopped or moved then pt isn't doing an auto fade or mute and the buffers pop |
I'm using an RME UFX. Not an Apogee and I am getting popping when I stop the playhead.
Same behaviour when using protools aggregate. |
M-Box 2 Mini - audio popping in playback | King Lou | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-08-2009 11:13 PM |
Constant Popping/Stuttering Audio Playback After Upgrade | jb1984 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-30-2008 01:53 PM |
M-Audio Octane & digi002 popping sound! | burgundysoundman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 05-31-2008 09:21 AM |
"Popping" sound during playback? | Celestial | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-12-2007 06:45 AM |
big problem-popping sound in audio | jmallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2004 08:04 AM |
