Old 02-02-2008, 12:28 PM
Petander Petander is offline
Default Re: Mbox 2 hum and computer data sounds ?
It's too cold up there right now to hum
The colder it gets, the hummer we hum.
Helps with groundloops too.
- i7 520 @ 3.6 GHz / P6T / XP32 / PTLE 8.01 . PT9 on Snow .
- PTLE8 on a macbook.
- And a bunch of miscellaneous obsolete hardware from the past. Like Mix ++++ 64 i/o with Control/24
I`m In The Band: www.ozofficial.com
My guitars are in tune : http://www.truetemperament.com/site/index.php
Old 02-02-2008, 05:40 PM
soundguy_2000 soundguy_2000 is offline
could be a ground loop.
could also be the audio connectors. i can make this happen by removing the output jacks just slightly (about 1-1.5mm). maybe try some different cables? i use neutrik connectors on all my cables.
also, is the input to your power amp 1/4" or XLR? if it's XLR, it might pay to check how they are wired. i.e.: are pins 1 & 3 bridged? what happens if you add/remove the bridge?
Old 12-01-2008, 05:08 PM
BCR40 BCR40 is offline
I believe I am having the same problem. I am trying to monitor the internal audio from my G4 while running Protools. I am using a 002.
When I plug headphones directly into the headphone out of the G4, I have no problems. When I go into the alt source inputs on the 002 or into 2 line inputs while monitoring through an aux, I get the noise.
I did some research and found that the G4's audio output is unbalanced and the 002's inputs are balanced and that this could be the problem. So I ran the computer's output through my radial directbox into a mic input on the 002 and the problem was solved except that I would have to buy another DI to get stereo. I bought the Samson S-converter, which supposedly takes an unbalanced -10 signal and makes +4 balanced, but still have the original problem.
Any suggestions?
Old 01-22-2009, 09:12 AM
Pentium Pentium is offline
Yes I thought about earthloop, however these usually appear only when
you have devices connected via audio I/O that are using different ring mains
there should be no difference in voltage potential for devices powered on the same ring.
I am not going to use iso trans on I/O for an Mbox.
I now have it connected to a unbalanced amp and the hum has gone.
Eleven Rack and computer: How to connect for audio data? el biciclista Eleven Rack 4 06-07-2011 11:38 PM
OT: Help! Computer lost data, no apparent reason northridgedave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-07-2004 04:08 PM
computer/game sounds thru 001 David Hardie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-18-2002 04:08 AM
Moving my computer, risk of data loss dummy20707 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-13-2002 11:30 PM
PT Hangs computer when recording MIDI data SirSmackaHo MIDI 1 04-06-2001 06:00 AM
