Sync problem
Hi! I have just finished working on the sound for a documentary. It is going to be on a few cinemas in Spain. When I went to see it for the first time at a cinema to check for any problems, there were 5 minutes of the film in which the sound and the picture weren't in sync. I went back to pro tools in order to check, but it was correct and in sync. We also checked the final video export from Premiere and it was also Ok. Nevertheless when it is projected in cinemas from a DCP or just projected from a computer through HDMI, these 5 minutes of the documentary are out of sync.
Has anybody ever run into a similar problem? Any ideas? Thank you all very much. |
Re: Sync problem
If it were a drift issue it would gradually loose sync and then wouldn't be back in sync. It sounds to me like an edit was made in the picture after your work copy and that 5 minutes slipped in the timeline.
Re: Sync problem
Yeah--the cut you were mixing to is not the cut they are using in the DCP. You have to find out the file name of what the DCP house has and check it against the name (and creation date) of what you used. It's possible that someone screwed up and send either you or the DCP house the wrong picture file. I'll give the benefit of the doubt to your picture dept that they didn't keep changing the picture after exporting it to you......although that HAS happened.
Sync Problem | Elvis Mcgarden | Pro Tools 10 | 1 | 03-05-2015 09:36 AM |
Sync I/O problem | BaileyBass | Pro Tools TDM Systems (Mac) | 8 | 02-17-2015 10:18 PM |
Sync I/O problem | Jerry_at_Sonus | Pro Tools TDM Systems (Mac) | 3 | 09-03-2010 12:07 PM |
sync problem | butchwolf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-02-2008 07:01 AM |
sync problem | Han | Pro Tools TDM Systems (Mac) | 4 | 11-19-2000 08:35 PM |
