Old 05-05-2010, 05:25 PM
Shatzer Shatzer is offline
Default pasting midi notes deletes others
Why is it when i want to copy some notes and paste them, the notes that are on different keys delete themselves? This is very annoying and frustrating to work with, almost impossible to work with. Is this a bug or am i doing something wrong?
For a better example:
I have a drum beat. Hi hat on F1, Kick on C2, Snare on A2 (i cant remember the exact notes but this is just an example)
I delete a measure of the hi hat but want to keep the kick and snare. I copy a good take of the hihat and paste it. This deletes the other notes. Why???
Old 05-06-2010, 12:07 PM
Julia B Julia B is offline
Default Re: pasting midi notes deletes others
It's annoying but a lot easier than recording a drum kit.
You're not doing anything wrong. It just does that.
You might want to change your grid from 16th notes to 32nds. Make your paste a little off, then slip it into the grid.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
Old 05-07-2010, 03:08 PM
ondruspat ondruspat is offline
Do you have "MIDI merge" selected??
"Sometimes having limits keeps you sane"- Albee1952
Old 05-07-2010, 04:39 PM
Thats a horrible work-around, why would they make it this way i wonder? I'll give it a go and see what happens, thanks.
Old 05-07-2010, 04:40 PM
Hmm, i don't believe so. I'll have to open up a project and make sure. Although i thought "midi merge" was to record midi data ontop of already existing midi data. Does that affect the editing as well?
Old 05-07-2010, 05:07 PM
Stig Eliassen's Avatar
You're doing something wrong.
For this scenario you have to merge the notes with the existing ones. Press Alt-M to merge the notes. Don't use paste.
Old 05-09-2010, 08:21 PM
Ah, i was hoping i was wrong. Thanks!
I still dont see the purpose of deleting notes when pasting. I guess Pro Tools is still a baby when it comes to midi editing.
Old 05-10-2010, 02:25 AM
I like the way PT works. If you want to replace a section with another, you simply paste over it. No need to delete notes to "make room" for the copied notes - pasting will replace.
And if you want to combine two sections you just merge them.
Old 09-20-2010, 03:47 PM
cruisemates cruisemates is offline
I was just struggling with this as well - but just place your cursor and hit alt-m instead of paste, it works just fine.
- but the second mouse gets the cheese
Old 03-26-2014, 05:12 AM
pauldavitun pauldavitun is offline
PT Lover saved the day and thank you ! I had the same problem when creating drum patterns. I got a good feel going on with 16 hi hats what with velocities and occasional slip to give it that real sound and feel,but every time I copied a few bars of it,the kick and snare were deleted so alt m is the way forward !
Here is my bands latest single - cheers
http://www.youtube.com/watch?v=3Tf146b4iDU
Copy and Pasting MIDI Notes Issue ianbee Pro Tools 10 2 03-02-2013 10:54 PM
Copying, looping, or pasting Midi notes Norm Mix MIDI 5 07-07-2009 10:23 AM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
Undo Record only deletes the Audio not Midi....? kirkgale Pro Tools TDM Systems (Mac) 0 01-19-2004 05:55 PM
pasting midi help please dBHEAD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-20-2003 12:51 AM
