New Markers -- no way to specify a marker END?
I see that AVID improved markers. I am trying to add a marker for a clip but not have it extend to the end of the session and without having to create another dummy marker. Am I missed this or did Avid overlook this?
Re: New Markers -- no way to specify a marker END?
Exactly--I want to create markers with a defined range that does not automatically go to the next marker, or to the end of the session.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
create a selection marker
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Thanks, I tried creating a selection marker on a single track, but can't get it to work. I've been through the manual, so I must be doing something else wrong.
I don’t think you’re doing anything wrong. Not at the computer to track but markers in Pro tools “go on forever” until the next one unless I’m wrong. I think even if you choose a selection instead of memory location the marker ruler still appears to continue on anyway even if had a defined selection in the memory locations window.
Pro Tools Ultimate 2024.3.1 MacBook Pro 16" Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine 32 GB unified memory 1TB SSD storage Ventura 13.6.4 |
The selection markers end up in the Memory Location window. The current Pro Tools UI is not designed to show them on a timeline. That would take changing how things are presented and the sort of thing that is hard to know what to do correctly with a timeline UI with potentially many overlapping selections.
And when you use those selection markers in the memory location window they most certainly "have a range" you see that in the edit window as you select any memory location. |
Selection markers work (on ruler or track.)
And it is as Darryl said. Open the memory location window! This is literally the point of them. There can be overlapping selection markers (as many as you'd like.) Marker's don't "continue to the end of the timeline" or "to the next marker." All you are seeing is the colour bar. That isn't the marker itself. Regular markers are just single positions.
I was hoping that with the Markers update it'd be possible to place something similar to a Post-It note directly on a track with a range determined by the edit selection. Maybe that's possible, but I haven't been able to do it yet.
That isn't how markers work.
If you want to do that, create a midi track and then a midi clip/region. Name the region your text. You can still create selection markers and put as much text as you want in the Comments section but it isn't visible from the edit window. You have to open the marker (from the memory location window) to see the comment.
In addition, comments are visible in the edit window for location markers in the current version of Pro Tools 2023.6.
Make sure the comments icon is turned on and blue https://youtu.be/FcLtOCu3v4U?feature=shared |
Removing Marker Attributes From Multiple Markers All At Once... | The Weed | Pro Tools 2020 | 1 | 08-22-2020 02:54 PM |
Quick way to delete Marker properties (when dealing with many Markers) | theblotted | Pro Tools TDM Systems (Mac) | 6 | 11-20-2009 09:12 PM |
Trying to set bar/beat marker, tempo marker won't conform | maitredebas | Pro Tools M-Powered (Win) | 0 | 07-31-2009 07:31 PM |
Key commands? Prev/next marker, renumber markers | BobK88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2006 01:41 PM |
Marker slippage - moving markers | bignick | Tips & Tricks | 5 | 07-04-2006 01:03 AM |
