Old 06-08-2018, 12:34 PM
sb_stefan sb_stefan is offline
Default "Assertion" error message upon opening Pro Tools
Been using Pro Tools 12.4.0 on OS X El Capitan 10.11.6 without problem the last couple of weeks, but today when I tried to open it I got this:
Could not create a new document because Assertion in "/Volumes/Development/158347/ProTools/DFW/Views/UMenu.MacOS.mm", line 1624.
What happened? How do I resolve this?
EDIT: I used an external hardware as playback engine earlier, which is now no longer physically connected to my computer. Can that have anything to do with it?
Old 06-08-2018, 01:34 PM
Default Re: "Assertion" error message upon opening Pro Tools
Could well be. Assertion errors like this are usually due to a misconfiguration in the audio I/O. The usual remedy is to hold down the 'n' key on the computer as PT starts up and then you can select the audio interface you want to use.
Jack
QAPLA!
Old 06-08-2018, 04:38 PM
Great! Thank you!
Strange "Assertion" error causing Pro Tools to quit unexpectedly...???? nickbradbury macOS 13 09-10-2014 03:50 AM
Help for Error Message - Assertion in "..\Mdie_TrackPlayer.cpp", line 476 lbpease Pro Tools 10 7 01-05-2014 12:15 PM
Pro Tools 11 - constantly get "your settings have changed" message opening sessions kirkbross Pro Tools 11 10 10-22-2013 07:36 PM
Pro Tools Error message Assertion in"/Volumes?/Development/ws.Preston/AlturaPorts etc db5 Pro Tools 9 4 11-16-2010 05:20 PM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 09:38 AM
