Extra Space End of Tracks
When I bounce out an MP3 or WAV from my song sessions, that file quite often ends up with about 30 seconds of blank space at the end.
I've been trying to find ways to bring up the end time in the session to avoid this but have come up blank. The actual clips in the session have no blank space at the end that I can tell. Any ideas on things I can look at? Thanks! Version 12.7, Win 10 PC Steve |
Re: Extra Space End of Tracks
Try selecting/highlighting only the audio you require - then bounce your song...
This should give only the audio selected in the final bounce... Sparky |
Thanks for the quick response Sparky. Sounds like that would work. I'll give it a try on the next mix.
If anyone has any ideas on preventing this before bouncing, let me know. Thanks again! |
Ideas? You've already been given the answer. Are you looking for another way to do it?
Timothy Ripley Composer, engineer, musician ripcurrentmedia.com [SIZE="1"]Mac Pro (Late 2013) 3.5 GHz 6-Core Intel Xeon E5, 32 GB 1866 MHz DDR3 AMD FirePro D500 3072 MB, Dual 4Tb Thunderbolt G Drives Acer B326HUL 32" 2560 X 1440, VIZIO video monitor Mojave 10.114.6, Pro Tools 20.3.0.163 Digital Performer 10.11, MOTU 1248 (Thunderbolt), MOTU 2408 MkII (x2), MOTU MTP AV USB (x2) |
I use two selection memory locations in every session. #50 is print/bounce, #51 is export - always.
I'll take a look at Stig's response for memory locations as well. |
To the OP, make sure there are no automation break points or anything after your clips. I think that would cause this to happen. But the simplest way of avoiding this is to do as suggested and just highlight the length of what exactly you want to bounce.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
I'll just stick with the memory location trick and not worry about it anymore. |
To the best of my knowledge, if you DON'T set a range - with either marker or the cursor tool - PT will simply bounce from the start of your session to the end of your session because that's what you've told it you want to do. By "Tabbing" to the beginning of the very first clip in your session and selecting a range from there to the end of your last clip (allowing for any FX tail of course) PT will bounce only between the start and end of the selection.
Hope this helps. |
Clearing extra timeline space in 12.6 | firmflange | Pro Tools 12 | 19 | 11-15-2016 10:59 AM |
FS: Avid Space and extra IRs New Price | michael c | Buy & Sell | 13 | 06-06-2015 11:06 PM |
FS: TL Space and extra IRs | michael c | Buy & Sell | 0 | 05-05-2015 03:07 PM |
Can I Get Rid Of The "Extra" Space Below Tracks In Edit Window... | The Weed | Pro Tools 11 | 12 | 01-02-2014 03:11 PM |
Large amount of extra space at end of track | Voice of Max | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-11-2012 07:22 PM |
