Old 06-07-2016, 06:59 PM
SteveGarman SteveGarman is offline
Default How to you detach and float a track module in Pro tools?
I can't find this anywhere.
Steve
Old 06-07-2016, 07:01 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: How to you detach and float a track module in Pro tools?
what's a track module?
Daniel
Old 06-07-2016, 07:18 PM
Sorry, that's probably an old fashioned term. But wait, Pro Tools still calls them tracks in their headings above your session. The fader modules are represented on the right side in the mix window-they are side by side with a fader in each one. There's a way to detach one of these faders so you can move it around to a better location. When I do ADR I have my video screen covering the mix window so it would be nice to have the fader for the production track over on the left window. I know you can "break" them out but I can't remember the command to do that.
thanks for any help!
Steve
Old 06-07-2016, 07:23 PM
Buccanears's Avatar
Buccanears Buccanears is offline
I think I know what you mean. In the edit/mix window, make sure i/o is visible and then click on the wee fader icon next to the output path.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 06-07-2016, 07:25 PM
Jperkins Jperkins is offline
You should see a VERY tiny fader icon in the mixer screen next to where you see the track output routing. If you click on that tiny icon, part of the channel strip should pop out and float but not all channel strip parameters are available when it pops out.
Old 06-07-2016, 09:12 PM
See my above post but here is an image of the button I'm talking about:
File Type: png Screen Shot 2016-06-07 at 11.10.41 PM.png (34.0 KB, 0 views)
Old 06-07-2016, 10:06 PM
Buccanears's Avatar
Onya Jperkins.
IMDB
Pro Tools 11 Fade Files 32 bit Float bug Matze1985 Pro Tools 11 0 07-31-2014 11:39 AM
Is Pro Tools internally 32 bit float point? Rockman413 Pro Tools 10 2 04-19-2012 06:40 PM
is 32-bit float processing available in NON-HD Pro Tools 10? mixupandblend Pro Tools 10 15 02-28-2012 02:54 PM
Can i detach windows in PT? Dan-Jay General Discussion 4 03-06-2010 09:08 PM
Need to run MIDI track from PT through a sound module Amnesiac MIDI 11 02-11-2008 04:08 AM
