Old 06-15-2013, 08:26 PM
gamblor gamblor is offline
Default clip gain on multiple tracks at once?
is this possible?
example, bass amp and di, both need some clip gain.
can i do both at once?
i haven't been able to figure that out yet.
highlighting both tracks didn't do it.
group didn't do it.
keybd shortcut?
thanks...
Old 06-16-2013, 12:26 AM
P,B,S P,B,S is offline
Default Re: clip gain on multiple tracks at once?
highlight all the tracks you want, then use the selector tool to adjust them.
Old 06-16-2013, 03:55 AM
bad jitter bad jitter is offline
Not front of my PT rig now, but If I remember right, higlighting the regions you wan to adjust and control-shift mousewheeling the cg value adjusts them all.
Old 06-16-2013, 04:33 AM
Phil Ogden Phil Ogden is offline
You can group clips across multiple tracks. That way a single clip gain adjustment affects all similarly.
Old 06-16-2013, 08:22 AM
Originally Posted by gamblor View Post
is this possible?
group didn't do it.
keybd shortcut?
thanks...
Group the tracks, select the regions, then shift-control- up or down arrow will trim clip gain as a group. You can also do it by displaying the clip-gain line in views and trimming with standard automation trim tools, but I find this less convenient.
best,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 06-16-2013, 09:09 PM
cool.
using the clip gain line with groups worked.
but not the up down arrows. caused mac screen to zoom in or out.
now, does it need to be in 'show clip gain line'?
or can you do it somehow with only the little clip gain fader?
thanks for all the input and help...
Old 06-17-2013, 03:56 AM
Yes if you use the method I outlined above i.e group the clips not the tracks.
Old 06-17-2013, 08:55 AM
but not the up down arrows. caused mac screen to zoom in or out....
Check your keyboard system prefs - you've probably got a system shortcut for screen zooming. Shift-ctrl-arrow will change grouped clip gains and display via clip gain fader.
best,
rich
Old 06-17-2013, 10:20 AM
OK, now front of my MacBook. First, you don't have to create any (track or clip) groups for the trick. Just select the regions you want to adjust and while pressing control and shift down use mouse wheel to adjust the level of their clip gain. Or like I am doing now with MacBook, using trackpad with two fingers instead of mouse wheel. Works great, is one of my favorite features and I use it almost every day.
What I don't like though, is that sometimes when adjusting clip gain you lose the numerical value shown in the clip, and I don't know how to get it back. Anyone knows?
PT10 Clip gain - multiple clips adjust at once? willco macOS 6 12-09-2018 08:39 AM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
Clip gain multiple clips workflow cjwalker Pro Tools 10 0 10-12-2012 02:53 AM
Clip Gain won’t update in real time during playback on Elastic Time tracks yanos macOS 0 06-03-2012 03:48 PM
Gain on multiple tracks? gastrocnemius 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-06-2008 02:20 PM
