Sending Quicktimes to an external display...
Hello!
Our post production facility utilizes the Apple ProRes 422 HQ format. They open just fine in ProTools, but my issue is: I need to play the video out through a fairly high-quality device that will send to a broadcast monitor. In the past, I have used devices like the Canopus ADVC-110, but it only worked in SD. It no longer appears to work on ProTools 9 at all. I need BOTH HD and SD video to output with the proper aspect ratio and full resolution. We now have an HD2 system on ProTools 9.0. Any suggestions? I REALLY need the quality to be good as this will display on a large client display. I'm hoping to use an INTERNAL card to the system as opposed to a firewire device (preferrably with an SDI output, but I can accept HDMI) and looking for minimal video delay. It needs to be accurate...or really dang close it isn't noticeable. Thanks for any help you can give! Ryan Salazar |
Re: Sending Quicktimes to an external display...
I was using a Canopus box but got tired of needing the files to be in DV format and SD.
I bought an ATI 5770 graphics card upgrade for my Mac Pro and now run three monitors, two 22" LCDs and a 46" LCD TV as the third. I'm able to run them from my machine room into the control room about 30 feet away using a dual DVI monitor extender for the smaller screens and HDMI for the bigger screen. The 5770 has 2 display port outs and one DVI out. I use adapters from the display ports to DVI for the small monitors and a DVI to HDMI adapter for the big screen. The videos look great on the third screen running in PT9 HD3. |
How about a Blackmagic Intensity card? They are PCIe, and have the options you are after.
Most of the Blackmagic stuff does HD, the Decklink line is extremely versatile.
I use a Decklink Studio card, it comes with a whack of outputs and a HDMI bridge. |
Yep Blackmagic. http://www.blackmagic-design.com/products/
We have both Decklink Extreme(under $1000) and Decklink SDI(under $300), the latter which is just SDI In/Out +Ref. |
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
Huge delay when sending from a channel which is record enabled to an external send | Thirtythr33 | macOS | 2 | 07-28-2013 01:03 PM |
External Display for Mix/Edit window | rakprachow | Windows | 2 | 10-26-2011 09:34 PM |
External Display Problem | probetools | Pro Tools 9 | 0 | 03-28-2011 06:48 AM |
Sending a track through an external Mic Pre. | potex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-10-2006 10:37 PM |
SENDING midi clocks (SPP) from PT5.1/MTP AV to an external XP80 sequencer... | Alécio Costa | Pro Tools TDM Systems (Mac) | 7 | 03-06-2002 12:51 AM |
