#461
Re: PT 9.01 Update IS OUT... and the freakin 003 console freeze issue is STILL NOT FI
Please report back how it went. Hi DTS, how's the repro case going and is there maybe any timeline for the fix? Quote:
#462
My 003 stopped freezing for awhile now. Mainly because I was using the same couple of projects.
Then I opened up an older project, don't know when I did it but it would have been an early PT8. It loaded to the point where it was probably checking the IO setup (remember it changed the order of inputs etc ) and then it BSOD'd. Since then I had a Mr Freezy. Q: Does anybody get the freeze and HASN'T got any out board MIDI gear? The reason I ask is that I beleive this thing is MIDI related. I am running a UM880 and MOTU 128 plus 1 port on the 003. So thats a total of 17 MIDI ports (some with multi channels) There is a lot of outboard MIDI gear. Yesterday I was doing something on an Alesis DMPro drum machine changing and saving things and it suddenly locked up. Checked the 003 and it was frozen too. Chicken or egg? Will investigate further.
================================== Win7x64 PT 9.0.5 DIGI003 Digimax FS ASUS P5E Q6600 6GB Eleven Rack + EXRP |
#463
In the beginning of the freeze issue I had an A33 controller keyboard connected. However, I disconnected it a couple of weeks ago, and did some fresh installs afterwards, and mr. freeze would still be there. So I doubt if it would be midi-related. |
#464
I almost never use midi but I still have the freeze issue.
#465
Nah, whether the freeze happens or not is not dependant on if any Midi hardware is connected or not.. it's probably more dependant on cosmic occurences or something
But I guess the freeze could cause some weird Midi events to be sent off the 003's MIDI outs... that could be an explanation why your DMPro locked up... dunno.. anybody else had some external Midi gear do weird things during a freeze? |
#466
Does anyone have a separate OS partition for pt8.03 and a separate OS partition for 8.0.4/9 as I have?
If so, is he/she experiencing the fact that after running 8.0.4/9 and rebooting to 8.0.3 partition, digi003 is not recognized and he/she has to re-install 8.0.3? Because to me that seems to point to some kind of settings/prefs (maybe inside 003 console) rather than something that stays within the OS/drivers/pt. I'm getting the impression some kind of settings inside 003 change because of pt8.0.4/9 (drivers?), that only get reset by re-installing drivers. Am I making sense? |
#467
- run pt9 until freeze happens - connect the 003 to a different computer running 8.0.3 if the same thing still happens, that would be a definite proof it's happening inside the 003. If not, as far as I can see, no conclusions can be drawn. just a suggestion of course... |
#468
...or maybe they might try it the other way 'round, as that might save some time installing the 2nd OS partition, and the second part of the test would only take a couple of minutes? |
#469
I don't use midi at all, and I have the freezes
#470
Would like to point out that the 003's screen goes blank for 3-4 secs when clicking on things (folders, controlk panel etc) EVEN BEFORE it has frozen.
You can switch the computer and 003 on, and before even starting protools try to click on different things, and the lcd screen will blank for a few secs. You know what? This is TOTALLY RIDICOLOUS. I am sure each one of us is spending 10 times more on this than DTS is. Someone said we are beta testers. I disagree, it is worse than that: beta testers just use it and report faults, we are suppose to fix them as well.... SHAME ON YOU AVID, SHAME ON YOU |
Digidesign Console freeze/ lockup issue during show......... | sbarnesvta | VENUE Live Sound Systems | 4 | 05-10-2011 04:11 PM |
002 Console Issue, Faders Wont Move (grounding issue?) | guitar486 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-01-2010 03:58 PM |
Plug In Racks&Console Freeze/Compatibility Issues | Zackdh89 | VENUE Live Sound Systems | 8 | 01-20-2010 01:31 PM |
Fixed: Intermittent Graphic Freeze When Using Pro Tools | crizdee | Pro Tools TDM Systems (Mac) | 4 | 10-03-2007 07:25 AM |
FIXED!!! HELP NEEDED!!! Need to work! Install disks freeze computer...WHAT TO DO??? | betsy | Pro Tools TDM Systems (Mac) | 40 | 07-31-2003 02:54 PM |
