Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-26-2009, 01:52 AM
kynk kynk is offline
Question FW or USB HDD ?
Hi everyone!
I have a dilemma. Since my 13" MPB has only one FW and 2 USB ports, i don't know what'll be better: to buy a FW hdd and daisychain it with ProjectMix, or buy a USB hdd (with external power supply, ofcourse) ?
thanks in advance.
Old 11-26-2009, 05:56 AM
systemexclusive systemexclusive is offline
Default Re: FW or USB HDD ?
Originally Posted by kynk View Post
Hi everyone!
thanks in advance.
On MBox 2 Pro there is 2FW ports. I guess one can be used to plug in FW HDD for audio files.
Old 11-26-2009, 06:46 AM
I forgot to mention, that i have PT 7.4.2 MP and ProjectMix. And have no intention to buy new interface.
Old 11-26-2009, 07:29 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
USB drives are NOT supported by Digi. Re-read their recommended specs before you make any changes.
There are also specific ways to loop-through the single FW conection using the I/O port of an external drive.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 11-27-2009, 02:12 AM
I know that USB drives are officially not supported, but i hear people are still using them.
I also hear, that problems will occur if i daisychain FW hdd and interface. (MAC->WD MyBookStudio->ProjectMix I/O).
Last option is to record onto MBP internal hdd ?
What do you professionals reccomend in this situation ?
My goal is to be able to record 16 track simultaniously.
Old 11-27-2009, 03:32 AM
mindnoise mindnoise is offline
Some HD-cases with the Oxford 924 chipset have all the FW and USB 2 connection.
get one of those casing and see what works best.
The thing is: Digi cannot not guarantee any stable performance with USB drives.
therefore they recommend FW drive, which have a more stable performance.
So with a USB drive 'you get what you get'.
Anyway, whatever Protocol you choose make sure it has a Oxford bridgechip.
best :)
last: PT11.3.1
Old 11-27-2009, 04:21 AM
pezking pezking is offline
I've had pro tools fail to launch because a usb drive was connected. Once.
I've had all sorts of errors trying to record to a usb drive, and have seen others experience a multitude of problems.
I have seen and heard of people running usb drives absolutely fine.
I have never had a problem using a firewire drive on the same bus an an interface (Mbox 2 Pro, 003 or Profire 2626). This is what I would do.
However the above recommendation of using a 924 chipset with USB and FW is a great idea - I'd still recommend the firewire though
HTH
Old 11-27-2009, 09:35 AM
Griffin23 Griffin23 is offline
USB is not supported but taht doesnt mean it doesnt work, just if something is wrong you wont get any support so you'd be stuck on your own.
I run an external 1TB WD USB HDD with my Mac mini and have had no problems what so ever but thats only me, theres people who are lucky and it works and then theres some people who's systems wont even load if a USB HDD in plugged in.
Basically do you want to play it safe or take a risk ? thats a question to ask yourself. Do You Feel Lucky lol
S.Griffin
Macbook Pro 16" (2019)
OS 10.15.7 | 2.4Ghz 8-Core Intel i9 | 32GB RAM
Old 11-28-2009, 11:17 AM
Sure i don't want to take any risks. I tried short 8-track recording to my external 1TB i'm Trekstor, for that minute or so there were no problems, ofcourse that doesn't show anything.
Old 12-10-2009, 01:52 AM
Now i have tested my new setup: 13"MBP w Snow Leopard!, PT 7.4.2, ProjectMix I/O, WD MyBook Studio 500GB.
If i hook it up: MBP FW800 -> WD HDD FW800 ->ProjectMix FW400 and try to record 16 tracks, it has cracks and pops on almost every channel. If i put the HDD to USB2, then it records flawlessly.
Is there any possibility to get the setup working on FW ?
