Old 04-14-2009, 11:49 AM
WildHoney WildHoney is offline
Default 3 sets of monitor outs from a C24? MOVED
I'm just moving into a C24 controller and am wondering if there's a way to get 3 sets of stereo monitor feeds coming out of it. Planning to have a composer station with 2 Genelecs, a mix station with 2 Genelecs and a sub and would love to have an alternate set at the mix station with some cheap-o computer speakers to which I've grown accustomed. Just at the beginning stages of this so go easy if I'm missing something obvious!
Old 04-21-2009, 08:56 AM
vga vga is offline
Default Re: 3 sets of monitor outs from a C24? MOVED
Yeah it would be nice to have an A,B,and C monitor switcher in the c24!
A couple thoughts would be to send the alt stereo feed through a switcher( like a central station) that feeds (2)or (3) sets of monitors
you could also use the SLS studio listen circuit if you do not have a studio to feed??
You could also play around with the 5.1 scenario if you are not using a surround set up. possibly you could use the rear feeds as 1 set, and the front feeds as another. not sure about its feasibility but worth exploring.
Old 04-21-2009, 11:21 AM
I don't need to use the Studio LS (this is separate from a cue mix to the live I assume). Can you clarify a bit how I'd work this out by using the SLS system? Sorry to be so ignorant of this board still. . . .
Old 04-21-2009, 07:34 PM
vga vga is offline
So are all of these stations using the same c24?
Are they located in the same room?
Old 04-21-2009, 07:56 PM
Yes, 1 c24 shared between two stations in the same control room. 1 station will have a small pair of genelecs, the other will have a genelec+sub set AND a pair of cheesy computer speakers.
Old 04-22-2009, 07:42 AM
vga vga is offline
OK
I would use the first 6 channels of your 192 to feed the genelec/sub, and then have ch 7/8 feed the cheesy computer speakers.
Then have the SLS feed the other genelec.
That way all monitors will have a separate pot on the c24
you can also get the speaker selector I spoke of earlier if you want more external solution
Old 04-24-2009, 02:36 PM
Originally Posted by vga View Post
OK
Thanks for the followup. One more question: if I use the SLS for the second set of Genelecs, will the talkback mic get spit out to those monitors as well?
Old 04-30-2009, 04:22 PM
vga vga is offline
I think that goes through the Cue feed normally
not sure if you can route to SLS
I will look into it
Old 04-30-2009, 05:01 PM
I will look into it
The goal here is actually to have the cue feed NOT go to SLS. As a default talkback goes to both the cue mix and the Studio LS mix.
Digi002 rack main outs vs monitor outs studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-03-2012 07:46 AM
3 sets of monitor outs from a C24? WildHoney Pro Tools TDM Systems (Mac) 1 04-14-2009 06:46 PM
Strange problem using monitor outs and outs 1+2 CCash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-11-2003 10:35 PM
2 sets of monitor speakers question guitarboy335 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 36 12-14-2002 12:28 AM
How can I have the monitor outs and main outs to the same input? voxpitch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-15-2001 09:16 AM
