Lost "Getting Started" Guide & Authorization Code
Hi everyone,
I was googling this topic, as I just got my Digi 001 back into my PC and am trying to get it running again. I realized that I need the authorization code (the computer has since been formatted a few times) again, but I can't find my "Getting Started" guide. All I have is the quick reference, the LE 5.3.1 disc, and of course the hardware. I noticed there are Digidesign Administrators here. Would one of you be able to help me with this? I can provide the necessary data like the serial number and model number. Thanks! Andy |
Re: Lost "Getting Started" Guide & Authorization Code
You should send that info directly to tech support. Or if you buy the 6,4 upgrade, it will come with a new authorization code. If you do update to 6.4, get the cs9 update as well(needed for indows XP service pack 2).
It's only $35 to buy the 6.4 upgrade for the 001 from the Digistore. I believe all you need to submit is the serial# of the 001 unit, not the registration# of PT5.
I'm think I called in the correct line (Customer Service). I picked the option for Authorization Codes -> Pro Tools before 6.9. But I was on hold for 30 minutes before I finally gave up.
I'm fine with just continuing to use 5.3.1. It's a rather old computer, and I know that 5.3.1 worked just fine with it. I noticed that there was an administrator that was able to give out an authorization code. Would that be the case here? Thanks, Andy |
Would 6.4 put an increased load on the system? Would I need to get new plugins?
I am considering upgrading to 6.4 if it will still work correctly and run as smoothly as 5.3.1 did. Thanks to everyone's input. Andy |
Big MAYBE to both questions. As I recall, system load went up as each update hit the market. As to how much, maybe someone else has better info. As for Plugins, once again its a MAYBE as they often do(especially dealing with a full version upgrade-i.e. 5.x to 6.x as opposed to 5.3.1 to 5.3.3). The real question there is what plugins do you have?
"Error, missing ILok authorization for "Pro Tools 10". | johkav | macOS | 4 | 09-10-2012 08:13 AM |
14 folders called "User Guide And Information" in workspace, and climbing. Delete?? | skronger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-13-2011 10:17 PM |
New Mbox Pro "Invalid Authorization Code" | envO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2011 09:57 AM |
**HELP** I LOST MY GETTING STARTED GUIDE (AUTH CODE) | Willosy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-06-2008 04:31 AM |
I lost my Protools getting started guide... | fathermac101 | Pro Tools TDM Systems (Mac) | 3 | 09-02-2003 05:52 PM |
