Old 04-10-2007, 12:04 PM
SixChurchStreet SixChurchStreet is offline
Default SPDIF cabling vs. Hi-Qual RCA cabling - difference?
I googled this a bit, but couldn't find my answer, so I figured I'd throw it by you knowledgeable folk, though it has little to do with Pro Tools!
Does anyone know the difference (or if there is a difference) between say... Hi-quality RCA cable and a SPDIF cable with RCA connectors?
And if there is a difference, can using BNC coax with rca adapters on it equal a SPDIF cable?
Just unclear on what's special/different about the cabling itself.
Kip
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4
Old 04-10-2007, 05:29 PM
rqstudio rqstudio is offline
Default Re: SPDIF cabling vs. Hi-Qual RCA cabling - difference?
Yes, SPDIF needs to be 70 ohm's
www.rickqueststudio.com
Old 04-11-2007, 07:58 AM
Musician's Friend sells spdif cable that's 75 ohms, not 70. Is this OK?
http://www.musiciansfriend.com/produ...ble?sku=330860
Old 04-11-2007, 08:35 AM
lemix's Avatar
lemix lemix is offline
Yes..75 Ohm coax. Any good quality cable will do. Shorter the better.
And if there is a difference, can using BNC coax with rca adapters on it equal a SPDIF cable? >> Kip <<
Same thing, although broadcast type BNC cables are more rigid and more appropriate for fixed installations.
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 04-11-2007, 09:13 AM
I have a ton of BNC wires at work, most are broadcast 75 ohm cables. awesome. I'm all set then. Thanks for the info.
Kip
Old 04-12-2007, 04:16 PM
FWIW, I have had zero trouble running SPDIF thru home made cables with the best Nuetrik RCA plugs and Mogami quad cable at 10'.
Cabling Help 6string Pro Tools TDM Systems (Mac) 2 01-06-2010 07:51 PM
Cabling C24 aztlan2010 ICON & C|24 6 05-21-2009 04:47 PM
Digital cabling Mario C General Discussion 1 05-07-2006 05:27 AM
192 Cabling Question rnt_u_listnng Pro Tools TDM Systems (Mac) 3 08-16-2004 03:43 PM
Please HELP ME cabling my HD3 New Studio!!!!!!!!!!! Mastersonics Pro Tools TDM Systems (Mac) 4 03-23-2003 12:03 AM
