Control Monitor Section STILL Intermittent!
Took it all apart. Sprayed TB3, TB4, TB2, blah blah blah...
with Dexoit. Re-set chips, wiggled connectors. Everything is tight & where it should be, but still audio just cuts out when it feels like it. Namely the Left side! I even tried anotherD-Sub cable with the same results. I've resorted to theALT monitor outputs for the past year. This was happeningeven before I changed the power supply a few months ago? It is in a stand and gets virtually no vibration... BTW, the Cub board is not cracked and is functioning properly. I'm at my wits end with this problem. I really would like to be able to use the monitor section for what it was intended. Any suggestions? Adrian |
Re: Control Monitor Section STILL Intermittent!
Adrian, I don't have the same problem with my C|24 monitoring section as you do -- I occasionally & get a very loud static "POP!". Digi support told me to deox some connectors, etc. but that hasn't helped. I'm now looking at bypassing/replacing the monitoring section with a Central Station or something from Dangerous Music. I've heard that Dangerous monitoring systems are more transparent than C|24 so that might be an improvement anyway. Maybe a nice XMas present for myself...
I know this is an old thread. but I'm a hopelessly intermittent poster...
Just wondering if this problem was satisfactorily resolved. I have had the same prob. with my Control 24 almost all its life. I've had a couple of psu replacements, but all to little avail. Oh and I still get occasional freaking out faders, leds and scribble strip flickering/dimming. But the left speaker thing is happens a number of times nearly every day... While I'm whingeing, I may as well add that my rubber's all sticky and one of my solo switches is dead now too. Waaaaaa! :cry: This is a pretty early unit and I am the original owner if that helps anything. I love you digi :) but definitely seeking help on this. Cheers, Hammers. |
The monitor issue is likely ribbon connections on the monitor board. The power connections alone would not cause that issue.
(Assuming it is not in a knob. I notice also on mine that occasional issues are easily resolved by cycling the alt button) Try cleaning and re seating the ribbons. If it persists, it could be a bad component on the monitor board. I went through a big issue with this recently, and I now have a NEW monitor board in mine. (Which has a constand barely audible his in the right channel.... both Mon and Alt.... might have to get a new one) The board will run you $450 flat out, or I think Digi will charge you only $150 if you return your old board. You'd have to call tech for varification.
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
PLEASE HELP!!! Control 24 Monitor section SURGING!!! | Table Syrup Records | ICON & C|24 | 2 | 01-07-2008 07:56 AM |
Upgraded monitor section on a Pro Control? | joesgarage | ProControl, Control|24, Command|8 | 2 | 10-16-2006 05:31 PM |
control 24 monitor section woes | insolace | ICON & C|24 | 4 | 05-18-2005 09:30 AM |
Monitor control room section | Tomio Broman | ProControl, Control|24, Command|8 | 1 | 05-19-2003 10:57 AM |
Pro Control Monitor Section-Please Read | Techsupt2 | General | 0 | 11-03-1999 03:38 PM |
