Old 12-31-2005, 12:10 PM
toddm7 toddm7 is offline
Default Mix I/O with regular (not M) Pro Tools
I'm looking for a control surface. What I really want is the CM Labs Motor Mate, but its listed at $2600. (Too Much) My question is, will the Mix I/O work as a full functioning control surface with regular Pro Tools?
Thanks
HP Laptop
Old 01-01-2006, 02:30 AM
bb_aus bb_aus is offline
Default Re: Mix I/O with regular (not M) Pro Tools
do a search
Old 01-01-2006, 03:49 AM
phobia phobia is offline
Hi!
I read it will work as either Mackie HUI (8 track) or Mackie Control unit, however if that is a "full fledged" control surface I do not know.
I used a Roland VS-2480 as a HUI controller to PT once, but I did find it somewhat limited compared to boxes built for the purpose.
Cheers,
// J
Digi 002
Mbox 1
Digi001 (retired to shelf)
Asus P5K Premium v3, Q6600, 2x2GB Corsair
Tyan Thunder n3600B (S2927A2NRF)
2xAMD OPTERON 2214 2.2GHZ
Win XP Pro SP3
Old 01-01-2006, 12:10 PM
thanks for the info.
HP Laptop
Upgrading from M-Powered to regular old Pro Tools... Will this cause problems? shotgunjoe General Discussion 0 03-11-2012 10:54 AM
whats the difference between regular pro tools and pro tools 9 academic? Abel0470 Pro Tools 9 5 01-20-2011 01:09 PM
fruity loops in pro tools question...not regular rewire question nutrinoland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-23-2010 12:39 PM
M-Powered and Regular pro tools on the same system jeroddumas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-10-2005 05:50 AM
Why have two versions of Pro Tools? (LE and regular) TedRackley Pro Tools TDM Systems (Mac) 85 11-30-1999 07:59 AM
