Old 10-25-2023, 06:47 AM
Default Re: Best internal SATA SSD for ProTools sessions?
Originally Posted by Farhoof View Post
Half my 870 evo's died, all due to faulty firmware. If you are running firmware version SVT01B6Q update is asap. Also do a sector scan for bad blocks.
All my drives were replaced under warranty (even the ones out of warranty).
Thanks, good to know, but the EVO and the QVO are different designs, so problems with one might not cross over to the other.
Only the QVO is available as an 8TB drive.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 10-25-2023, 06:48 AM
I have the 870 QVO as backup drive. It is solid 350MBPS drive limited by SATA interface.
Thanks. Still faster than my 12TB G-Drive which manages 150MB/s on a sustained copy, not including disconnections and starting all over again.
Dominic
Old 10-25-2023, 08:44 AM
SomeOtherGuy SomeOtherGuy is offline
For backup I have three 8 TB 870 QVO drives in external OWC cases, so far so good. But I might add that these drives are also fast enough for sample libraries too, while simultaneously running video in PT. And I was only using one of the drives for both.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 10-25-2023, 09:11 AM
Thanks. Which OWC cases do you use - I had the Envoy of some description when I upgraded my 2015 MBP internal SSD, to hold the old chip as an external drive. Clever idea, but slow.
Dominic
Old 10-25-2023, 09:15 AM
Dominic
I got Mercury Elite Pro mini cases:
https://www.owc.com/solutions/mercur...pro-mini-usb-c
Old 10-25-2023, 09:25 AM
Thank you!
Dominic
Old 10-25-2023, 10:00 AM
smurfyou smurfyou is offline
I like these. I use it with two EVOs
https://eshop.macsales.com/item/OWC/MEMDC2KIT/
Can be bus powered or use its power supply. Still small enough to be portable. (I use as independent disks not RAID)
~Will
Old 10-25-2023, 02:18 PM
audiolex1 audiolex1 is offline
They are about 2 times bigger though. No need to have an external power supply. All will be powered from a hub easily.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 10-25-2023, 03:35 PM
Tweakhead Tweakhead is offline
I've had great luck with all Samsung SSDs (except QVO), and also Crucial.
Darryl's firmware post was invaluable.
I have also noticed a sad downhill run with WD products. I stopped buying anythink they make (include G-Tech, which they now own - and install their crappy SMR mechanisms into). I had one fail irretrievably after a few hours use. Luckily it was only being backed up to when it failed.
anyone tried something like these dual SSD enclosure/hubs with a Mac Studio ?
1. Example 1
2. Example 2
3. Example 3
Old 10-27-2023, 11:02 AM
Eric Lambert's Avatar
1. Example 1
2. Example 2
3. Example 3
I haven't, because I've already set things up a different way, but if I were starting over again I'd consider one of those.
ProTools Boot drive migration to a new internal SATA drive audiowave Pro Tools TDM Systems (Mac) 1 05-03-2011 03:45 PM
Internal SATA for storage? SoundWolf76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-19-2011 01:19 AM
Best Internal SATA H/D for PT8LE? plangentmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-16-2010 11:04 AM
Internal SATA vs eSATA??? StinkyStan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-26-2009 02:43 PM
Internal SATA or external FW? test tube AUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-03-2007 10:13 PM
