Old 08-21-2005, 04:05 PM
hiphopsupamix hiphopsupamix is offline
Default got M Powered on DAW. can i use it on Laptop too?
hey guys,
I have M Powered on my DAW at home (using it with Audiophile 2496). I'm now considering getting a Laptop as well, can I use M Powered on my laptop as well or is there a limit to how many workstations I can install it on?
Also, I'm obviously going to have to get an M Audio soundcard for my laptop if I want to use M Powered... is there an M Audio equivalent to the Mbox or something basic like that?
thanks
Old 08-23-2005, 11:00 AM
DigiTechSupt's Avatar
Default Re: got M Powered on DAW. can i use it on Laptop t
You can use it on any machine, as the authorization for it is on the iLok - you need to have the iLok plugged into the computer you want to run Pro Tools M-Powered on.
Avid Audio Tech Support
Support FAQ
Old 08-23-2005, 11:44 AM
sleepwalk sleepwalk is offline
Default Re: got M Powered on DAW. can i use it on Laptop too?
thanks
from this site "Compatibility", check out these
For the Following M-Audio Hardware Systems Only:
FireWire 1814
FireWire 410
FireWire Audiophile
FireWire Solo
Ozonic
Delta 1010
Delta 1010LT
Delta 66
Delta 44
Audiophile 192
Audiophile 2496
Pro Tools M-Powered supports the use of any single supported M-Audio peripheral. Simultaneous use of multiple M-Audio peripherals is not supported.
Old 08-23-2005, 10:42 PM
thanks for the replies guys
any suggestions on what soundcard to get for my laptop? I'm looking for an M Audio soundcard that is similar to the Mbox
thanks
Will my Laptop run M-powered 8 - AMD cpu? senorvivo Pro Tools M-Powered (Win) 1 02-05-2009 12:58 AM
ProTools LE & M-Powered LE on the Same Laptop Jala Pro Tools M-Powered (Mac) 4 10-03-2007 02:43 PM
ProTools LE & M-Powered LE on the Same Laptop Jala 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-15-2007 07:45 AM
M-powered and PT LE on same laptop Neale Eckstein Pro Tools M-Powered (Mac) 4 03-28-2006 04:30 PM
Best laptop for m-powered 7 Sean O'Rourke Pro Tools M-Powered (Win) 2 11-04-2005 11:14 PM
