Only 200 memory locations ?
Does anybody know why we have this limit. A limit like 256 or 512 I'd understand, and I really just need a 50 more or so.
Does anybody any way around this limit. I'm doing a voiceover editing and and its a bitch to try to find sentences (subject to constant script changing) if I wouldn't mark them up. I'm using WinXP pro and PT 6.4.1 with MIXplus ...jonhallur |
Re: Only 200 memory locations ?
That is correct - there's a limit of 200 for memory locations. I do not know why specifically, but I will try to find out from engineering and get back to you.
Anybody have any ideas on this one? Just ran into the same problem. Arggh.
thanks, dave |
Please also ask them why we can not transfer memory locations between sessions and why they don´t appear when exporting sessions as text (especially the selection markers) cheers, frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
... aahhhhmmmm what was your question??? (tach axel:))
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD |
This limit bit me today! Why this ridiculously low limit? Please fix it!
1. On the source session, create a MIDI track 2. Export MIDI (save a MIDI file - both 0 and 1 MIDI file formats seem to work) 3. On the destination session, import MIDI to track (locate the just saved MIDI file) 4. You've done But I agree, you should be able to do this using Import Session Data command. |
Oops, I just realized that this is a Windoze, not a Macintosh forum. I don't know if the previous works on Windoze...
Memory Locations bug | stargazer | Pro Tools TDM Systems (Mac) | 5 | 04-29-2011 05:46 AM |
Memory locations | RW1965 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-04-2006 05:27 AM |
memory locations | Fave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-05-2002 11:32 AM |
Memory Locations | Fave | Pro Tools TDM Systems (Mac) | 2 | 04-05-2002 05:01 AM |
Memory Locations | Rams Boy | Tips & Tricks | 1 | 03-07-2000 03:10 PM |
