Re: how-to Direct Connect
There isn't a lot to know!
What problems are you having? There is a DC manual on the technical documents page - check the link at the top of this page Pete |
Hi there several steps to setup NI app in DC. I would contact NI Tech Support so they can send you manual on this.
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
You really should find what you need in the manual from Native - but to summarise:
Ensure that a DC plugin has been installed in your system/dae/plugins folder - FM7 or something like that. Start PT, open a session. Create an aux track (stereo) Create a midi track Start FM7 Ensure that it's output is set to direct connect and that it's midi input is set to one of the iac busses provided as part of OMS. Switch back to PT, set the output of the midi track to the same IAC buss as FM7 uses. In the first insert slot of the aux track, load the FM7 plugin and select the inputs (probably 1-2) from the drop down. Press play - this will get the link going (this might not be necessary on LE systems, but on D24 systems where you use RTAS d/c you need to do this). Then stop, record arm the midi track and whatever you play should trigger the FM7. Hope this helps Pete |
Thanks guys! I'm almost there. Now it starts but when I switch to the fm7 I lose midi control. Also lots of stuck notes.
Peteri: your directions were great!! why can't manuals be so concise and clear? |
Specifically my problem is an oms error
"OMS has too much midi data to send for over 5 seconds. This could mean there is a mid loop. Carefully check your software midi routings especially ones between applications" so...here's my setup G4/450, serial midi via stealth port, studio 4 iinterface. any trouble shooting ideas welcomed |
Just checked it and only my midi controller was selected in PT.
In the FM7 settings, should the "midi through" be checked? (mine is) For "midi output port" I have the just FM7 listed. For "receive inputs from" I have just my controller keyboard listed. Thanks again for the help! |
Can anyone point me to some DC turorials. I'm having problems with the FM7 and my G4/450 9.04. I can't seem to find any tutorials on the subject. If anyone has any leads, kindly post the url.
On a slightly unrelated topic, does anyone know how to get FM7's internal tempo to sync to ProTools? I'm sending midi beat clock out the IAC bus in OMS to the FM7, but it ignores it.
I'm running 5.1. I need to switch to enable oms "run midi in background". Gonna try it again tomorrow and let you guys know.
Direct Connect? | RGrierson | Pro Tools TDM Systems (Mac) | 1 | 02-05-2002 09:58 AM |
Anyone use Pro 52 and Direct connect? | Blake Henderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-10-2002 03:39 PM |
Direct-Connect BUG? | Henrik | Pro Tools TDM Systems (Mac) | 16 | 11-29-2001 01:09 PM |
Direct connect? | Chompers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-14-2001 08:42 AM |
Direct Connect for NT? | Echo studios | Pro Tools TDM Systems (Win) | 1 | 06-29-2000 03:25 PM |
