Re: ProTools 12 Ultimate - CPU Overload without playing
Hi
Well you should is recommended by Avid here is the guide : http://avid.force.com/pkb/articles/t...Optimize-10-13
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Ultimate Overload
I'm so sorry, but as you for sure have figure out, english is not my mother language. I will keep you posted if I find the culprit plugin of this issue. Thanks!
Mac Pro 3,5 Ghz 6-Core Intel Xeon E5. 64 GB 1866 Mhz DDR3. High Sierra 10.13.6 ProTools Ultimate 2019.5 Interfaces 3 x 192 I/O + 1 x Apogee Rosetta 800 Logic Audio 10.4 |
Have you tried removing/disabling plugins one-by-one (or in batches) yet?
#16
What up Alpine Texas? Small town...been through there a lot on the way to MX. Alpine, Marfa, Ojinaga.....All beautiful places
#17
OMG....not often I find someone who is familiar with Alpine!
#18
So many of these kinds of issues revolve around plugins...
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
#19
Hi There,
Finally I could perform the different tests with the plugins. Indeed I have found a plugin that could be the cause of a percentage of the problem, exactly 15% of the problem, the plugin is: "Abbey Rever Plates" from Waves. Then I have found another plugin, this time from Avid, that is the culprit of another 3% of the problem: the reverb "Revibe II". In the mix in which I have been making my tests I had two instances of Revibe II, so removing those two instances I have saved a 6% from the CPU overload. At this moment my CPU is around 40% in the mix session. The rest of plugins do not give any relevant problem, only if I'm removing one by one the CPU usage is decreasing as I deactivate plugins. But there is no plugin that reduces 15% of use, not even 1%. If I delete all the plugins, the CPU consumption drops to 1%. ALL these tests without doing at any time PLAY, with ProTools completely stopped. Is it a problem of de-normalizing plugins or ProTools 12? I am inclined to think that it is rather the second, and in truth this never happened before. Tomorrow I will try to activate my old computer with PT10 to measure the CPU, but I do not remember that the CPU even reached the 30% in mixes that exhausted the 192 voices of PT10. And much less with ProTools completely stopped. It's crazy! Every time I regret more to have moved to ProTools 12. BTW, I said that I have never done any optimization to my system, but actually, I did. And I could not found nothing in the info from Avid for High Sierra that I had not done previously in any machine I have had in all these years. Any ideas? People from Avid.... Are you there? Thanks in advance!
#20
Uninstall and reinstall all your Waves plugins (its easy enough to do with the current waves installer to do them all). I believe there were some fixes for Sierra/High Sierra.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
ProTools 8.0.3 and Windows 7 Ultimate hate me!!! | cornhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 05-13-2010 05:51 PM |
Vista Ultimate 64 (the ultimate dissapointment) | Filmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2009 04:44 AM |
Using Mainstage 2 to run AU softsynths inside ProTools - the ultimate NI fix? | PastaViking II | Pro Tools TDM Systems (Mac) | 3 | 07-26-2009 05:27 PM |
CPU overload in protools 6 with OSX | John@wombatstudios | Pro Tools TDM Systems (Mac) | 5 | 05-10-2003 04:17 PM |
