After some time touring on monitors with the S6L, I've come up with a few new features I'd like to see in future software updates. I also put these on IdeaScale, but since there doesn't seem to be much activity there, I'm putting them here too.
New Events -Solo a mix or channel via GPI/Footswitch/Function Key. Especially on the S6L with its Soft Key section, this would be especially handy. -Level change to a channel or mix via GPI/Footswitch/Function Key. My specific ideas is to allow a performer to remote control their own mix level via 2 footswitches, one that goes up in 1dB increments and one that goes down by 1dB. This could also serve as a boost for solos, etc. -Turn on/off individual plug-ins via GPI/Footswitch/Function Key. I know this can be done in Snapshots, but I'd like to have individual control without having to navigate to the Plug-in page. Custom Favorite Layout -I want to be able to see a combination of Inputs and Outputs on the Favorites screen, as opposed to having to tap back and forth between the two. -It would be nice to be able to add blank spaces between channels in the Favorites view so I can group things in a way that is quick to recognize. Soft Key Labels -Add the ability to label Mute Groups and Function Keys on the Soft Key screen. Tape labels on a shiny new console with a perfectly good screen are so passe. And you don't want to push the wrong mute group key at the wrong time because you remembered the wrong assignment. As you can see, I'm a fan of customization and remote control. Let me know if any of these functions already exist and I've missed them. And go vote for them on IdeaScale. |
![]() Quote:
But it's not a solution for Mute Groups anyway. |
![]() Quote:
I like that as a solution for the function keys, but would still want Mute Group labeling at some point. I'm not in front of a console right now, but if I remember correctly, there are 2 lines in the Mute Group Screen that both say the same thing, one in red and one in white. Could one of those be user write-able? |
![]() Quote:
Thanks for the suggestion about the snapshots triggering a single fader move. I set it up and my artist is psyched. She used the pedal a good bit on the first night with it.
The setup is this: I Recall Safed everything on the console except one Aux master fader. I created a bunch of snapshots with the fader at -16 dB through +12 dB, and start at the 0 dB point. From a dual footswitch Boss FS-6, the A switch connects to GPI-1 and the B switch to GPI-2. GPI-1 goes recalls the previous snapshot,and GPI-2 advances one. Of course, this locks you out of using snapshots for anything else, but in my case that's OK. |
You don't have to recall safe everything else to make that work.
Just scope ONLY the single aux master you want in the snapshot, and only select Fader. In the snapshot scope,
This will recall ONLY the fader level of that single fader that you've scoped when you hit this snapshot. I attached a screenshot of what it should look like. |
Thanks Ryan. I always forget that the fader view on the snapshot page serves a different function than the one on the other pages.
You could still use a normal song-per snapshot list in conjunction with this, the challenge would be that when the artist triggers their snapshot it will screw up your order, so simply hitting next is out, but midi driven snapshot recall could be a way around, perhaps a Qlab front-end. I realize you didn't ask for this idea, but I like solving problems, even when they may not exist yet
![]() Quote:
Already on it, non-linear snapshots is a big deal, as are nested snapshots!
VENUE 3.1.1 Software Now Available | Avid Pro Mixing Support | VENUE Live Sound Systems | 0 | 10-29-2013 01:24 PM |
New Venue Software with S3L | n8white | VENUE Live Sound Systems | 2 | 06-27-2013 05:25 AM |
Bug in Venue 3.0 Software | Limelight | VENUE Live Sound Systems | 2 | 04-02-2012 10:01 AM |
New Venue Software and PT9 ?s | Limelight | VENUE Live Sound Systems | 1 | 12-10-2010 04:37 PM |
VENUE D-Show 2.8 Standalone Software for VENUE SC48 | Avid | VENUE Live Sound Systems | 0 | 05-13-2009 01:30 AM |
