Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 06-23-2016, 10:38 AM
JustinT JustinT is offline
Default New S6L and Venue software wish list
After some time touring on monitors with the S6L, I've come up with a few new features I'd like to see in future software updates. I also put these on IdeaScale, but since there doesn't seem to be much activity there, I'm putting them here too.
New Events
-Solo a mix or channel via GPI/Footswitch/Function Key. Especially on the S6L with its Soft Key section, this would be especially handy.
-Level change to a channel or mix via GPI/Footswitch/Function Key. My specific ideas is to allow a performer to remote control their own mix level via 2 footswitches, one that goes up in 1dB increments and one that goes down by 1dB. This could also serve as a boost for solos, etc.
-Turn on/off individual plug-ins via GPI/Footswitch/Function Key. I know this can be done in Snapshots, but I'd like to have individual control without having to navigate to the Plug-in page.
Custom Favorite Layout
-I want to be able to see a combination of Inputs and Outputs on the Favorites screen, as opposed to having to tap back and forth between the two.
-It would be nice to be able to add blank spaces between channels in the Favorites view so I can group things in a way that is quick to recognize.
Soft Key Labels
-Add the ability to label Mute Groups and Function Keys on the Soft Key screen. Tape labels on a shiny new console with a perfectly good screen are so passe. And you don't want to push the wrong mute group key at the wrong time because you remembered the wrong assignment.
As you can see, I'm a fan of customization and remote control. Let me know if any of these functions already exist and I've missed them. And go vote for them on IdeaScale.
Old 06-23-2016, 02:17 PM
Valentyn Valentyn is offline
Default Re: New S6L and Venue software wish list
IMHO this is something to be done via dedicated iPad/iPhone/Android/etc monitoring app. Yes, it's not available at the moment, but still - it's the most proper kind of solution for this.
Good question in general regarding Favorites vs User layout[s]. User layout can have spaces, but this doesn't really make sense for favorites. Maybe Favorites should be somehow united with User Layouts.... Any thoughts?
Soft Key Labels
Will automatic labeling via Event name work for you? I.e. if some Event has a function key as a trigger, then Event's name will serve as a name for the function key.
But it's not a solution for Mute Groups anyway.
Old 06-23-2016, 05:52 PM
I'm looking for something that is very simple, and hands free, like for a singing guitar player who can't reach their IEM belt pack mid-show. I've done something similar before with a volume pedal sending MIDI signals to control an Aux master fader on a PM5D, but it was kind of a kludge to make it work. Triggers from a dual switch pedal (like the Boss FS-6) would be simple and elegant.
I can see that working. I'm currently not using the Custom Layout, so it could be used in the background to arrange the Favorites screen. However, if you introduce multiple Custom Layouts, that might change.
I like that as a solution for the function keys, but would still want Mute Group labeling at some point. I'm not in front of a console right now, but if I remember correctly, there are 2 lines in the Mute Group Screen that both say the same thing, one in red and one in white. Could one of those be user write-able?
Old 06-24-2016, 04:08 AM
RyanJ's Avatar
RyanJ RyanJ is offline
Agreed! This would allow you to do some cool workflows, such as flip a mix to faders, plus pull up a custom layout for that mix with one button press.
You can use a GPIO trigger to hit a snapshot that scopes ONLY one fader, this would be doable.
Agreed!
Also Agreed
Soft Key Labels
Those default names are there for a reason, so you can change them! Coming soon.
Ryan John
Principal Product Manager | Avid Live Sound
ryan.john@avid.com
Old 07-07-2016, 01:49 PM
Thanks for the suggestion about the snapshots triggering a single fader move. I set it up and my artist is psyched. She used the pedal a good bit on the first night with it.
The setup is this: I Recall Safed everything on the console except one Aux master fader. I created a bunch of snapshots with the fader at -16 dB through +12 dB, and start at the 0 dB point. From a dual footswitch Boss FS-6, the A switch connects to GPI-1 and the B switch to GPI-2. GPI-1 goes recalls the previous snapshot,and GPI-2 advances one.
Of course, this locks you out of using snapshots for anything else, but in my case that's OK.
Old 07-07-2016, 09:45 PM
RyanJ's Avatar
You don't have to recall safe everything else to make that work.
Just scope ONLY the single aux master you want in the snapshot, and only select Fader.
In the snapshot scope,
  1. double click the 'none' button next to the fader strips, to select NO strips of any type.
  1. click the aux masters you wish to scope (both left and right if it's a stereo pair).
  1. select "fader" in the scope section.
This will recall ONLY the fader level of that single fader that you've scoped when you hit this snapshot.
I attached a screenshot of what it should look like.
File Type: jpg Screen Shot 2016-07-07 at 8.43.23 PM.jpg (97.5 KB, 0 views)
Ryan John
ryan.john@avid.com
Old 07-11-2016, 10:41 AM
Thanks Ryan. I always forget that the fader view on the snapshot page serves a different function than the one on the other pages.
Old 07-11-2016, 04:48 PM
Brent Lind Brent Lind is offline
You could still use a normal song-per snapshot list in conjunction with this, the challenge would be that when the artist triggers their snapshot it will screw up your order, so simply hitting next is out, but midi driven snapshot recall could be a way around, perhaps a Qlab front-end. I realize you didn't ask for this idea, but I like solving problems, even when they may not exist yet
Old 07-12-2016, 05:33 PM
Kristo Kotkas's Avatar
Kristo Kotkas Kristo Kotkas is offline
This is actually something Avid guys should think about how to fix in the system... there should be a way to have a song snapshot list and independent layer of snapshots or events or whatever you call them, that would handle the other tasks on the desk without messing up the song snapshot list.
Old 07-14-2016, 12:21 PM
RyanJ's Avatar
Already on it, non-linear snapshots is a big deal, as are nested snapshots!
Ryan John
ryan.john@avid.com
VENUE 3.1.1 Software Now Available Avid Pro Mixing Support VENUE Live Sound Systems 0 10-29-2013 01:24 PM
New Venue Software with S3L n8white VENUE Live Sound Systems 2 06-27-2013 05:25 AM
Bug in Venue 3.0 Software Limelight VENUE Live Sound Systems 2 04-02-2012 10:01 AM
New Venue Software and PT9 ?s Limelight VENUE Live Sound Systems 1 12-10-2010 04:37 PM
VENUE D-Show 2.8 Standalone Software for VENUE SC48 Avid VENUE Live Sound Systems 0 05-13-2009 01:30 AM
